Question about Epson LX-300+ II Matrix Printer
Printout My printer is not taking page for printing. Power is on and light is blinking. I have checked my Ink Cartridges my Black Ink Cartridge is full but color cartridge is empty. the sound of page taking is coming from printer but its not taking page. Please help me Exper.
    Novelist:
  • 135 Answers
The paper is pulled in with rubber traction wheels on a rotating rod toward the bottom of the paper loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use. More information on that printer available here: http://www.retrevo.com/search/fv/63aac4a52ebe6e8d638f91867c39f9be.pdf#page=1
Posted on Aug 02, 2007
SOURCE:
Canon 1p2770 ciss ink cartridge is not recognized
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Oct 27, 2017 | Canon PIXMA Office Equipment & Supplies
I bought a replacement black ink cartridge and the cartridge light won't stop blinking or respond at all. Are these cartridges defective?
1.) Reset your printer
2.) Make sure the cartridge are properly inserted.
3.) Does the light still blinking? Try printing a test page if it can print.
Mar 18, 2011 | Office Equipment & Supplies
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Blinking light--won't print
give a try to dis one..
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
ALL THE BEST
Mar 22, 2009 | HP Deskjet 6940 InkJet Printer
No PRINTOUT, only blank page/ no page received
Dear Teleios
'power button blinking without taking a paper to copy' usually means paper jam or no ink error.
First ensure you have no paper jam and you just replaced both ink cartridges.
If the printer still does not print, or does not print colors or black ink, then the ink must have dried up on printer head/nozzles.
You can try using clean nozzles option from hp printer software several times, and see if this fixes the problem. If it does not you will need to physically clean printer heads inside with solvent and cotton. To do this you need to disassemble part of the printer.
Having same work done in a service centre should cost around 50 euros.
HP DeskJet 3820 InkJet is not an expensive printer, if you cannot fix it with a clean head / nozzles from software you may also consider buying a new one for slightly more than the price of a cartridge change.
Regards
Mar 24, 2008 | HP DeskJet 3820 InkJet Printer
HP OfficeJet K60 Printer
you can bypass when asked and use last good settings by..Press and hold the Enter button, and then press Menu
This problem is caused by incorrect alignment page print out caused by faulty cartridges, ideal fix is replacement of all ink carts
HP have a webpage dedicated to this...h10025.www1.hp.com
Also get on your gloves get out your vac and suck on the carts till a little ink comes out, make sure colour cart releases all 3 colours then reinstall, can get messy.
Oct 19, 2007 | Office Equipment & Supplies
Help
Me is Vikram Kumar Thumu, I have seen your message on the  issue related to the HP Deskjet 5150 Printer. I would like to provide my suggestions on this issue.
The issue could be happen due to following below reasons:
1. If you are using wrong ink cartridge for the Printer.
2. If you are using a refilled ink cartridge
3. If there is an issue with fault with ink cartridge or an issue with ink cartridge slot in the Printer.
4. If there is an issue with Hardware malfunction of Printer.
Well, to resolve the issue I recommend you to try below solutions.
Note **: Your Printer supports below ink cartridges:
Cartridge Part number Black HP 56 (C6656A) Tri-color HP 57 (C6657A) Photo cartridge (optional) HP 58 (C6658A)
Check whether you can installed correct ink cartridges for the Printer or not.
Solution 1: To Hard Reset Printer once.
Make sure that Printer is disconnected from the computer.
1. Turn ON the Printer.
2. Raise the top access door of Printer. The carriage assembly should move    towards center of the printer.
   Note: for some printers carriage will not move to center.
3. Remove both ink cartridges from Printer.
4. Power OFF printer by pressing the power button of the Printer.
5. Disconnect the power cord from wall outlet and Printer cable (USB or Parallel) from the back of the Printer.
6. Let the Printer remain disconnected for at least 60 seconds.
7. Reconnect power cord and Printer cable (USB or parallel) at back of end Printer.
8. Turn ON the printer.
9. Reinstall both ink cartridges into Printer, make sure that they lock into position and installed in correct ink cartridge slots.
10. Close the top access door firmly.
once if you are done with steps, check the issue. If the issue still persists then please go ahead with next solution.
Solution 2: To Clean the ink cartridges and Cartridge slot in the Printer
Please open below web link.
Link is:
Once if you have opened the web link, please perform the steps that are mentioned in the web page for cleaning ink cartridges and also steps for cleaning ink cartridge slot assembly in the Printer.
I hope that this should resolve the issue. However, if the issue still persists then please go ahead with next solution 3
Solution 3: Testing the ink cartridges of the Printer
To isolate the issue by testing the Printer Hardware functionality with " Reserve mode printing " ( this is also called as 'Back up mode'). This is referred as using the Printer with only single ink cartridge. Your Printer model supports for this feature.
Steps are :
1. Open top access cover of Printer and remove the Black ink cartridge from Printer ,make sure that Printer is installed with Color ink cartridge only . Then close the top access cover firmly. Please turn off Printer and Wait for 30 seconds and then turn ON Printer. Check the status of blinking lights on the Printer. If you do not see any blinking lights on the Printer front panel, then cartridge is fine. We can now go ahead with testing Cartridge functionality along with Hardware test of Printer.
Please do these below steps to test Cartridge and hardware of Printer:
1. Turn the printer on.
2. Press and hold the POWER button until step 4.
3. Press the RESUME button four times.
4. Release the POWER button.
This should print a self test page. If you see any information printed on the page, then it confirm that Printer and cartridge is fine else if there is no information printed on the page then it confirms that Cartidge is Out of ink.
Note: you may receive a error code on the test page, please do not worry about that.
Please do below steps similarly to check the issue with Color ink cartridge..
Open top access cover of Printer and remove the Color ink cartridge from Printer ,make sure that Printer is installed with Black ink cartridge only . Then close the top access cover firmly. Please turn off Printer and Wait for 30 seconds and then turn ON Printer. Check the status of blinking lights on the Printer. If you do not see any blinking lights on the Printer front panel, then cartridge is fine. We can now go ahead with testing Cartridge functionality along with Hardware test of Printer.
I hope this should resolve the issue. If the issue still persists then you may need to service the Printer once.
If you any issues related to the Printer further you can mail me at [email protected]. I will be glad to help you.
Oct 03, 2007 | HP DeskJet 5150 InkJet Printer
Epson LX-300+ II Matrix Printer Logo
189 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
