Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Fridge digital display is showing CE, WATER DISPENSER BOT RUNNING WATER AND MOTER IS NOT ON
  • Official Brand Answer
  • 4,342 Answers
Hi berniekeenan -
Error code CE typically indicates a communication issue between the user interface and main control board. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the refrigerator back on. If the error code continues, I recommend scheduling service so a technician can accurately diagnose and repair your refrigerator.
Posted on Apr 23, 2013
  • debbie samuels Sep 22, 2013
    Chris, How can I thank you!! I had tired the circuit breaker once before, but had turned it right back on. This time I waited 10 minutes and turned it on, at first, the fridge turned on and off constantly and I was concerned that I had made the problem worse, however, I opened the fridge and freezer doors for a few moments and this made the reset work. Now the beeping I have listened to for 24 hours has stopped and the touch pad, ice and water all work again. You are brilliant. Thanks !!
WHEN IT DISPLAYS 5Y CE WHAT DOES THAT MEAN?
The SY CE error indicates that the user interface (key #2) and the main control board (key #38) are not communicating properly. You can check the wiring. Unplug the refrigerator and gently pry the the dispenser away from the refrigerator. (Use a putty knife and work around the edge of the dispenser.) Check that the connections are clean and tight. Check the connection under the hinge cover, as well.
If the wiring doesn't have any damage, one of the above boards needs to be replaced. Additional testing will be needed. If you add a comment with the model of your Frigidaire, I may be able to provide information about the parts.
I hope this helps.
Mar 12, 2015 | Frigidaire Refrigerators
Refrigerator temperature shows 60 degrees but waterline is freezing
yes thermastat maybe bad check sencer for temp it maybe bad
Aug 29, 2014 | Refrigerators
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
5y CE code on frigidaire refrigerator water/ice dispenser
Dear Sue,
  • SY CE Error Codes is a very common issue : the display board isn't communicating with the main PCB.
  • Unfortunately, there is no way to test which board is causing the problem. That's why this error can be costly.
  • Try to just unplug the refrigerator for 15 minutes and plug it back in to see if the error goes away.
  • If the issue doesn't go away, then you'll need to replace one or two boards.
  • Usually the Main Control Board under the refrigerator behind the kick panel is the part that tends to fail.
  • If you Change the Main Board, it does not work; you gonna have to replace the Display Board.
  • Try buying these board at an online store that accept Returns without conditions up to a year. Go online and put the boards number into any major search engine. Put the # one by one. You will find many sellers. Carefully pick one and do you homework
Good luck and keep me posted please,
JP
Jan 13, 2013 | Frigidaire Refrigerators
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Jan 18, 2012 | Hotpoint Dishwashers
GE refrigerator is not working. the lights are on in the inside of fride and freezer but the fridge isn't running. My external digital temperature controls, water dispenser, ice cube dispenser, is not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
qrtgfs
Jun 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge will not stop flashing zeros diagnostic
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
Mar 20, 2010 | GE Refrigerators
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
309 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
