Question about JVC XL-MC2000 200-Disc CD Changer
ERROR 13 ON THE JVC XL-MC2000
EVERY TIME I TRY TO PLAY THE MACHINE SHUTS DOWN AND I GET A CODE 13 WHY. I CANT GET THIS TO STOP, CAN YOU OR DO YOU HAVE A SOLUTION FOR THIS ANNOYING PROBLEM? SHOULD I DUMP THIS MACHINE OR KEEP IT. PLEASE RESPOND.
ITS A JVC XL-MC200 COMPACT DISC AUTOMATIC CHANGER.
THANKS
CHRIS
3 Suggested Answers
SOURCE: cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Posted on Mar 09, 2008
  • 3247 Answers
SOURCE: NEED OWNERS MANUAL FOR JVC COMPACT DISC AUTOMATIC
Hope you can find it on
http://audio.manualsonline.com/mdownloads/72c57941-ba72-1114-49cb-5d69ab6b6572.pdf
good luck
Posted on Dec 25, 2009
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
DO YOU HAVE A MANUAL FOR OPERATION I HAVE A JVC 200 XLMG2000
http://resources.jvc.com/Resources/00/00/90/LVT0359-001B.pdf
Apr 20, 2010 | JVC XL-MC2000 200-Disc CD Changer
What buttons do i push for a music cd or anything to play?
I can send you a manual if needed. kb3xy@krbenson.com
Dec 12, 2008 | JVC XL-SV22 CD Player
Cd player skipping
The DVD transport rides on chrome rails. These get dust and stuff on them and wont allow the optics to track.
If you dare, open the unit UNPLUGGED from the AC.
See if you can get at those rails easily. clean with WD40 on a swab. clean with a new swab . then a couple drops of mystery oil on a swab and run down the rails over and under.
You must be VERY gentle if you clean the lens with isopropyl
Oct 05, 2007 | JVC XL-MC2000 200-Disc CD Changer
CD CHARNGER PROBLEM
if your machine had never given that problem then the problem is in the microchip which needs to replace.good luck.
Apr 26, 2007 | JVC XL-MC2000 200-Disc CD Changer
JVC XL-MC2000 200-Disc CD Changer Logo
382 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
