Question about Sony Bravia V-Series KDL-52V4100 LCD TV
Tv is running on 480psd and I want 1080p
Need info, to make adjustment
    Problem Solver:
  • 9 Answers
The resolution depends on the inputed product you are using
eg a dvd will run on max 760 p unless you are using a hdmi cable tv only runs at 1080i bluray will ru at 1080p if using a hdmi cable
Posted on Mar 11, 2009
I keep gettin "no TV Signal" on my Emerson EWL20S5C when i plug in a indoor tv antenna. DoI need a converter box. I live very close to tv towers. HD
I cannot seem to find info on the version "C" model, but everything I find on the base model appears that is is not a digital unit and does not have a digital tuner. Thus it would need a converter box to tune digital HD channels. That said, the specs also say that the set can handle 480p/480i/1080i inputs. Thee is no mention of 720p/720i/1080p capability, which funnily enough, most US TV HD broadcasts are in 720p or 1080p. You may find you need a new set.
Jul 25, 2016 | Emerson Televison & Video
My 42 wont stay on,it powers up stays on for a min. or two screeches real loud then shuts off, than comes back on...this is all it does
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 07, 2015 | Generic Hisense 42" Class LED-LCD 1080p...
Hello.im from malaysia..i have using 42" LG LCD tv..when i see info..i feel confuse because at box it say Full HD 1080p ready but when i see info, it only 1080i 50hz..how can i change this?
You do not change the resolution at the TV, the vidoe/signal sources will dictate what it will display on the TV, if it is fed with 1080i it will display 1080i. If you want 1080p, your video source will have to be 1080p. It works the same as your PC monitor, you adjust the resolution at the PC, not at the monitor.
I hope I explain it well enough.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Televison & Video
I have a 738 - 73" and I cannot set it to 1080p (only 1080i). What is my problem?
If you are referring to the signal information displayed on the screen, it is only detailing only what the TV is receiving. By that I am referring to the signal the cable box or DVD player is sending to it. You need to make the 1080p adjustment on the HDMI device (PS3, DirecTV box, etc).
The display of the TV is by default 1080p all the time. This is the native format for the TV display. All signals coming into the TV (even the Wii or VCR) are upscaled to this format in order for them to be displayed.
I hope this was helpful, best wishes.
Mar 06, 2011 | Mitsubishi Televison & Video
My ps3 wont show up on my tv screen it is a 42 inch plasma it will not show up it keeps saying invailed format what do i do?
Your 22 monitor is set up (most likely) with a max resolution on 1650x1050 and you ps3 stays set to that even when you use it on your dads 1080p TV (1920x1080) and since your 22 in monitor is a non-standard resolution (in the TV world that is ) ie 720p = 1280x720 and 1080p = 1920x1080 it has to adjust to the closest resolution (your ps3) but sometimes the auto switching of resolutions doesn't work like it should..it just doesn't work sometimes. I suggest that when you take it to your dads you adjust the resolution to 720p ahead of time (a resolution both the 22 monitor and tv should be able to handle ) and when you get to his house it should work at least enough to see everything and then when already there you can adjust up to the higher 1080p (1920x1080). Then adjust back to 720p before you go home again. Sorry for the long winded post.
Here is a link to resolutions explained in case it helps.
http://en.wikipedia.org/wiki/File:Vector_Video_Standards2.svg
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Jan 31, 2011 | Televison & Video
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
My tv only shows 720p and i am not sure how to adjust it to 1080p ={
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
May 06, 2010 | Insignia 42" LCD Flat-Panel HDTV
1080i on tv and not 1080p
No. Most broadcasts are limited to 1080i. BlueRay discs and (now defunct HDDVD) are the only time you will see 1080p. I heard DirectTV may also be running 1080p soon (or already have the option). In any case, 1080p requires 2x the bandwith vs. 1080i. I assure you that unless you see them side-by-side, you will not notice the difference. You many not notice the difference when you do see them side-by-side. The broadcast controls the 1080i vs. 1080p (not a setting on your TV).
Nov 17, 2009 | Cars & Trucks
Can't run ps3 1080p to tv, but can to surround sound
dude im sure its ur TV cant be bith 1080i and 1080p not sure that works like that, sorry just stick to what the TV is
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Bravia V-Series KDL-52V4100 LCD TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
