Question about Yardman Yard-Man 13AC76LF055 38-Inch 344cc 12-1/2-HP Powerbuilt Briggs & Stratton 6-Speed Transmission Riding Lawn Mower
Got the cutting deck on my riding mower stuck going thru a tight gate...engine stopped and won't start again, why?
Believe some safety features preventing it from starting
Engine stall when cutting it want start how to start engine when cutting deck is down
Posted on Nov 03, 2013
  • Yardman Master
  • 2,478 Answers
Check your bladles , for turning freely.
Posted on Apr 20, 2013
  • Joseph Apr 20, 2013
    Blades not turning are not an issue
Motor won"t turn over, with new battery.
this might be something as simple as a safety switch , your gonna need to look at three that im sure won't allow it to start if not in working order . they are the occupant (seat) switch , next is the clutch depressed switch and last is the mower deck engauge lever switch all of these are safety switches to keep you from starting engine into a dangerous condition , also ck your cables to battery (both ends) clean and tight no wiggle and most important Plus(+) to plus side of battery and neg (-) to ground of frame , don't feel offended i suggest something so basic you can't belive how many mowers i get thru here with the battery installed backwards
Jun 09, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
I have a Craftsman mower, model 917.273810, and when you engage the blades, the brake pads that are used to stop the blades from turning when you disengage the blades...won't release and it trys to...
Sounds like you have a broken spring #148 on diagram, part #169022 that holds the idler arm back. Go to www.searspartsdirect.com and enter the model # of your mower and click on the mower deck to print drawing out, take your deck off the mower and see if all the springs are ok. If the pads are closed on the pulleys and the pads release when you turn the idler arm, the deck is ok. The problem will be a bad or disconnected safety switch that cuts the motor off if you try to ingage the mower. If the switch is disconnected under the seat it will kill the engine when the mower is engaged. I had this problem on my mower, just plug the wiring into this switch or replace it if it is bad.
Aug 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The deck blades stop turning in reverse unless switch is pulled.
This is a safety feature that is not that hard to do so i say live with it.You do'nt have to hold it up just pull it up before you start backing up and once your moveing you can let go without it shutting off the deck until the pedel returns to neutral again,all tractor have it by law after a certain date so jumping around it is niot a good idea.
Nov 30, 2009 | Garden
Starting Craftsman model 917.270430 riding mower.
There's a safety shut-off switch below the seat, so when you're seated the switch is engaged. If you were to fall off the mower, the engine and Blades stop (safety feature).
Check the switch to see if it's operational.
Beyond that, mower may need a tune up or servicing, if it is not starting.
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Riding mower Safety Tips
Lawn mowers in general can be dangerous, but riding mowers and lawn tractors are even more so. Some models have better safety features than others. You’ll want to look for, at the very least: * A system that prevents the engine from starting unless the blade is disengaged and the machine is in neutral. * An automatic blade shut-off that stops the mowing blades if you stand up rather than sit on the machine, or if you leave the mower/tractor. * A system that stops the blade if you shift into reverse, or at least a lock that requires you to make a deliberate decision to mow in reverse.
Aug 27, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Yardman Yard-Man 13AC76LF055 38-Inch 344cc 12-1/2-HP Powerbuilt Briggs & Stratton 6-Speed Transmission Riding Lawn Mower Logo
238 people viewed this question
Top Yardman Garden Experts
Dennis Key
Dennis Key
Jerry Kramer
Jerry Kramer
Daryl Gleaton
Are you a Yardman Garden Expert? Answer questions, earn points and help others
