Question about Gateway 7210GX Notebook
Restore sound While attempting to clean up and make more room in my computer memory I must of done something to my sound. The volume controls are all up and I do not have a reinstallation CD. What do I need to do or what do I need to buy to get it up and running again.
  • Bill Kindle May 11, 2010
    Were you uninstalling any programs when you were cleaning up your computer? I may be able to help you but need a little more info.
  • 94 Answers
Try to reinstall your audio driver click here to download driver
Posted on Mar 12, 2009
I unplugged my sound system to re-arrange the living room and when I plugged it all back in it just wouldn't turn on at all. no lights, no nothing. I tried it in 3 different outlets and then in an...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 31, 2011 | Logitech X-540 Computer Speakers
I've got Creative Inspire M2600 model. When I increase/decrease the volume using volume controller knob, sound in the right speaker goes off.
Does it come back after your done adjusting? Or do your have to do something else to get it back? If its just during adjustment then its probably the design of the speakers.
Jan 05, 2011 | Audio Players & Recorders
When I hook up my computer to the receiver and play music it is hard to find a point on the master volume where the music plays clearly. The music skips and i have to be very careful with the master...
Master volume control pot is dirty and needs to be cleaned out. You can do this by unplugging the receiver and turning the master volume control back and forth from zero volume to full blast a couple of hundred times to clean the surfaces and restore normal operation.
Aug 24, 2017 | Pioneer VSX-509 Receiver
I can not get a sound in my computer
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 31, 2010 | Computers & Internet
The speakers in my computer are blown out and need to know how to go about getting this fixed??? I can't hear anything when I attempt to play something with sound. Thank you, Michelle
are they physically blown out or are you just!!!!!!
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 25, 2010 | Computers & Internet
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Cant get sound to work
Hello welcome to Fixya, there several reasons that can cause the sound not to work on your computer.The first thing you should do is to check the volume on your computer to make sure that the volume is up and if you keyboard has volume button make sure that the volume is up.If you done all of this and still can't hear no sound please go to the manufacturer website and download the sound drivers for your computer. You can also download the sound drivers from other websites such as:
Please remember that if you see the word audio drivers that also mean sound drivers.
Thanks for choosing Fixya
Jun 10, 2010 | Computers & Internet
I am seeking to restore my computer to an earlier date to get my sound back
You can only restore once you have made a restore point. Then you can restore your system back to the time of that restore point. I don't think going back to a set restore point is going to fix your sound unless you made changes to volume and configurations like muting your sound. Restore points won't put your drivers back in if they are damaged or missing. Open "Control Panel" and then go to "Sound and Audio Devies" Click the option to put volume in taskbar and then open the volume control. Make sure that "Mute" isn't checked and slide the volume controls back up. You should also go to "Control Panel" and "System" then to "Device Manager" and make sure you can see your sound card an that there isn't a mark next to it. Check with the manufacturer of your computer system and see if there are updated drivers for your sound card.
Nov 22, 2009 | Microsoft Windows XP Home Edition
Tv rca televison model DZ7649 Entertainment series
  • there is a loose contact in volume control or switch.
  • clean volume control with cleaning chemical & change volume switch.
  • hope this will help.
Oct 12, 2007 | Televison & Video
Gateway 7210GX Notebook Logo
192 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
