Question about Klip Xtreme KSD-320 Cable & Combination Lock
How to reset combination cable - Klip Xtreme KSD-320 Cable & Combination Lock
Ms 6541 front panel conection
in the lower right corner to find F-P1 18-pin, 3 rows of 2 cables combined as follows: hard drive LED pin 8-blue, red pin 9; button-black power pin6. white and yellow button pin 7 pin9 ready, green Pin8, not only takes away the reset button cable ready source of power and resets
Jun 17, 2014 | Intel Motherboard
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
Reset combination lock
The cable lock should come with a small pronged key used to change the combo, if you lost the key you can try getting a replacement from HP.If not you will need to cut the cable and buy a new one.
Nov 18, 2011 | Computers & Internet
Cannot unlock my husbands tsa lock we are in argentina
To set/reset combination on TSA Cable Lock
TSA Cable Locks come preset from the factory to 0-0-0. Set the combination to 0-0-0 or your already chosen combination. if different than 0-0-0. To set the combination, use a pointed device such as a pen to press in on B. While pressing on B (do not release B until combination is set), pick your 3 digit combination.
Once all 3 dials are set to the combination you want, release B. Your TSA Cable lock Is now set to your combination. TSA Lock will NOT be locked at this new combination - turn one or more dials and your lock will be locked. To unlock, follow instructions above.
Please make sure to remember your combination!
You can also use the video below:
http://www.youtube.com/watch?v=OfchUwkEckI
Good luck..
Aug 26, 2011 | Locks & Locksmithing
I found 2 Kryptonite combination cable locks out of a storage box and do not remember there combination! Both are open! Is there a way for me to reset combination while there open? Thanks Denys
Probably not. But a simple solution for this is to turn the numbers and listen for a click when the tumbler locks into place. You' should be able to get the combination from both locks by doing this.
Aug 07, 2011 | Kryptonite Kryptoflex 1218 Combo Cable...
Hi, I bought a Krypto bicycle lock over 5 years ago. I don't see it displayed on your website. It has yellow ends with 4 digit combination numbers red on black.The rope cable is grey and has a clear...
Krypto has the resetting of the combination lock on their website (under Maintenance) but if you cannot unlock it in the first place you can not reset the combination. You have to know the old combination to get it open.
Feb 23, 2011 | Kryptonite Cycling
How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
Note: Using excessive force can damage the dials.
Step 3. Set the new combination while maintaining the position of the "RESET" dial.
Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
Sep 07, 2010 | GE Home Security
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
Post. (Figure 1)
etc.
original position.
combination.
Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Klip Xtreme KSD-320 Cable & Combination Lock Logo
Top Klip Xtreme Home Security Experts
Lawrence Oravetz
Are you a Klip Xtreme Home Security Expert? Answer questions, earn points and help others
