Question about Andis AGC2 Hair Trimmer
Power comes and goes
When I turn the power switch to the on position 50/50 chance it will power up, I notice that if I hold them at a 45degree angel I have a better chance of them powering up,however now they just will not power on at all
  • 191 Answers
Hi I know its a late reply but this sounds just like a power cord problem you can buy a new mains lead for the clipper from UK based company Anglia Clipper Services
Posted on Feb 11, 2014
Which power steering hose goes where in the rack in pinion
Hi William:
I'd just hook them up and try it. There's a 50:50 chance you'll have it right. If it does not turn easily, switch them.
Sep 20, 2015 | 2000 Mercury Sable
Eninge lite blinks fast and wont start
Pull any error codes.
The engine light lights up when you turn the ignition switch on, then goes off. After four seconds, if it comes on again and stays on, there is a present fault code. When it is an historical fault code, it comes on with ignition and goes off then comes on and goes off again. I believe in like 4 second intervals. A historical code will not be removed until a cycle of 50 ignition on/of intervals has passed. In other words, the engine light will continue to light two times when ignition switch is turned on, after 50 on/off cycles have passed the historical codes will no longer affect the engine light when starting.
If you will hold the odometer button on the side of the console down, and turn the ignition on and off, three times I think, waiting for the fuel pump to stop before turning the ignition switch to the off position, and one second until you turn it on again, the third time holding the odometer button down until the engine light begins to blink it will begin to blink in a fast sequence showing the fault codes will follow.
First indication of fault code display is rapidly blinking engine light. After that count the number of times the engine light lights up. There will be a brief pause between digits. If there are multiple codes stored, the rapid blinking will separate each. Once the fault codes begin to repeat, you have gone through all stored codes.
Tips: Have a pencil and paper ready.
Maybe ask a friend to help out. Sometimes a second pair of eyes can be good.
Go through a couple of cycles, so that you are sure you haven't missed any codes.
One example is if it blinks 3 times, pause, the blinks 2 times, that means 32.
Code 32: Rear Fuel Injector
Feb 16, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it...
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Dec 27, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
Free tv repair advice
Hitachi 42" plasma TV all of a sudden death. Power failure, no lights on the front panels. No signs of life.Found solution through my very honest repairman called Johnny's TV Repair in Hollywood:
There is a kill switch to protect against power surges. Located under the bottom edge nest to where the cable goes in the body, all you have to do is press it back in and voila; LET THERE BE LIGHT and probably save yourself a min $200 trip to the repair shop. Of all the places my friend called non mentioned this switch so next time you have TV problem and can't fix yourself go to this guy if you're in Los Angeles. Johnny's TV 4452 Melbourne Ave Los Angeles, CA 90027 (323) 660-9900 1df09a55-a543-44e3-9508-ff918ce89dd4.jpg
May 26, 2013 | Emerson LC320EM9 32 HDTV LCD TV
Engine will not start
Do you have power on the small wire at the starter with the key in the crank position? Something else you can do is pull the starter relay. One pin should have power all the time (power from the 50 amp fuse number 9). One pin should have power with the key in the crank position (power from fuse 10 via the ignition switch. The other two pins should be grounded. One goes to the starter solenoid and the other goes to the neutral safety switch. Let me know what you find and I'll see what I can do!
Oct 12, 2012 | 2000 Dodge Durango
My Insignia 37" has a problem. The picture is everything I want it to be, but the problem is that it only turns on sometimes. When I push/hold the power button down, I can see the light slightly flicker...
I asume that the "on/off" button is covered with plastic. When the temperature is cold, the plastic cover shrinks and and puts pressure on the button underneath towards the "off" position, when the temperature is warmer the plastic expands and releases the button. What you could try is to take a hair dryer and some sticky tape and heat up the plastic membrane.When warm,apply the sticky tape to the plastic and pull on it and hold it until the plastic cools off. This should stretch the plastic membrane over the pushbutton and fix the problem. Caution, do not get to close with the hair dryer or you will melt the plastic membrane. Good luck
Oct 05, 2010 | Insignia 37" LCD Flat-Panel HDTV
Overheating from dust
These sets rarely shut down from dust. Chances are that the Temp sensor has failed. It is located on top of the lamp housing on the Light Engine. To test this you must locate the temp sensor and short with a test lead or wire across the two terminals and make sure the interlock switch is held in the up position, then turn on the set and see what happens. If the set stays on then the temp sensor is bad. If the set still shuts down then and goes straight to "Stand By" the you have a bad power supply. Make sure you have a good Lamp installed as this can cause the same symptom.
Apr 11, 2010 | Samsung HLM507W 50" Rear Projection HDTV
Road angel won't charge / turn on?
Take memory card out, hold the power button for 15 sec to put it on, now do the same putting it off. Put back memory card and turn it on, it should work now. Johan. South Africa
Sep 18, 2009 | Vehicle Parts & Accessories
1992 honda accord ex sometimes starts sometimes not
you have a small power(ICM)_ module that is heating up. it's square with 3 promgs 2 on 1 side 1 on the other. I believe it's on the back side of the distributor. 2 screws hold it on/ and the neutral saftey could be giving you problems. it's 1 or the other.
Aug 31, 2009 | 1992 Honda Accord
Andis AGC2 Hair Trimmer Logo
94 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
