Ethernet to USB Print Server for canon MP610 multifunction
Anyone know of a compatible ethernet to USB Print Server for canon USB MP610 multifunction unit for Windows 8. Thanks,
  • 40 Answers
The MP610 is a GDI printer (which lacks intelligence to convert the page into dots on the page, and uses the Windows graphics engine instead). These printers are inherently hard to network. Often the only way is to share them via a PC. Below link has a driver that's claimed to work with Win 8. Alternatively, you could try the Win 7 driver on the Win 8 machine.
http://support-au.canon.com.au/contents/AU/EN/0100012601.html
If you want to use a printserver, you need to make sure it supports your printer. For each printserver, go to the manufacturer's website. There should be a list of supported printers for each printserver. If the list is not there, or if your printer is not in the list, you must assume that it will not work.
Scanning will almost never work with any printserver
Posted on Jul 14, 2013
5 Suggested Answers
  • 14 Answers
SOURCE: I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Posted on Oct 13, 2008
kleeper
  • 87 Answers
SOURCE: Can I connect the printer directly to my laptop using ethernet cable
Hi! If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies. For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab. NOTE: Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel. Access the Embedded Web Server Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
  1. Press Setup on the HP All-in-One.
  2. Press c00706174.gif until Network is highlighted, then press OK . The Network Menu displays.
  3. Select View Network Settings menu, then press OK .
  4. Select Print Network Configuration Page , then press OK . A configuration page prints, including the IP address. You will use the IP address in the next step.
  5. In the Address box in the Web browser on the computer, type the IP address of the HP All-in-One, as shown on the network configuration page. For example, http://192.168.1.101 . The Embedded Web Server Home page displays, showing information for the HP All-in-One. NOTE: If you are using a proxy server in your browser, you might need to disable it to access the Embedded Web Server.
  6. If you need to change the language displayed in the Embedded Web Server, do the following:
    1. Click the Settings tab.
    2. Click Select Language in the Settings navigation menu.
    3. In the Select Language list, click the appropriate language.
    4. Click Apply .
  7. Click the Home tab to access device and network information, or click the Networking tab to access more network information or to modify network information.
  8. Make any configuration changes.
  9. Close the Embedded Web Server.
Good Luck!
Posted on Oct 24, 2008
SOURCE: Can I wirelessly network my HP Officejet J5780 printer?
What you are saying will not work . The J5780 only connects with a USB. It does not have a J45 connection. So to play with the "built in network server" would do nothing. You would have to have some way to convert the USB to a J45 so he could hook it to his Wireless Router. His only alternative is to hook it to another computer that is used as a Wireless Slave that is shared or to get a print server. Hower, Belkin does make a wireless USB Hub that converts 5 USB's to J45 and can be hooked to you Wireless Router. It also has a built in Print Server. You can take this device and instead of hooking it J45 to the Router you can hook it to a linksys Bridge and now the USB HUB from Belkin becomes completely wireless. And has a Print server to boot! The model number are Belkin "Network USB Hub" and the Linksys WET54G.
Since the Hub connects to the USB devices and then converts them to a J45, to link to a network you can hook it to the llinksys device and convert it to a wireless network usb hub. It also has a print server built in.
It works. I own the same printer all in one and if you search on the internet you can pick up both devices on the cheap.
Posted on Jan 16, 2009
SOURCE: When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
Posted on Apr 03, 2009
How to share printer with two computer on IR 2020?
Does the ir 2020 have ethernet
http://www.canon-europe.com/For_Home/Product_Finder/Fax/Laser/Features/Optional_Accessories/UFRII-LT_print_kit.aspx
The easy way is to share the printer out on one of the p.cs and then add the printer on the other pc. Draw back is Sharing P.C has to be switched on all the time for other p.c to print.
I know how hard it is to get after market support for photo copiers. You may be able to use a USB print server and then plug it into a Ethernet hub or Switch and set up the IP addresses on the two p.c's and the Print server.
Jan 29, 2015 | Canon Office Equipment & Supplies
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
What print server can use for panasonic kx-mb771 gdi
search for USB print server . tThere are ethernet ones 10/100 Mb/s and wireless 802.11G . You need computers to be on ethernet or wirelss network also ! Your printer uses a high speed USB port see http://www.panafonic.com/b2c/product_info.php?currency=USD&cPath=59&products_id=591&language=en
Nov 27, 2014 | Panasonic Office Equipment & Supplies
IR 1600 print server
Interface Connections Ethernet (10/100BaseT) (Optional)
IEEE 1284 (Parallel)
Token Ring (Optional)
Any print server that offers the above connections, do a Google search.
Mar 12, 2014 | Canon Computers & Internet
Instead of using a usb cable, I want to print wirelessly from laptop or iPad to my Canon PIXMA MP810 Printer. I have a wireless router with spare ethernet plugs at rear. What are my alternatives ? for...
You could purchase a ethernet print server which will allow you to connect your printer to the router via ethernet cable. I recommend the TPLink TL-PS110U. I use this for one of the printers in my office.
http://www.tp-link.com/en/products/prodetail.aspx?mid=0103030802&id=194
Alternatively, you could purchase the TPLink
TL-WPS510U. This is a wireless print server. It will give you some freedom if you wish to locate your printer to somewhere other than beside your router.
http://www.tp-link.com/en/products/prodetail.aspx?mid=0103030801&id=181
May 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
Mar 06, 2009 | Canon PIXMA MP610 InkJet Printer
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
100 people viewed this question
jasbo
jasbo
