Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
Makita 6916D impact driver sick
I have 6916D that is acting like it has a run down battery . The removed battery will show 13+ volts . There seems to be more power in reverse . The brushes are good and no sign of any thing out of order inside . Any ideas ?
    President:
  • 1,996 Answers
Do you have a second battery to check whether the fault is with the drill or the battery?
If you have more than one battery and you experience power loss with both, confirm that the charger is charging properly by using a different charger, if possible.
Sounds like it might be time to purchase a new battery. You could take it to a local Makita distributor and try a fresh battery to see if that does it, but after time even these rechargeable batteries need to be replaced.
I'd say that's the culprit 90+% of the time.
Thanks for trying FixYa!
Posted on Mar 30, 2009
I have a makita dc24sa charger and i need to no if it will charg a 14.4 battery
Yes, the DC24SA will charge any Makita battery between 7.2 and 24 volts that will properly fit the battery slot.
Mar 07, 2014 | Makita Tools & Hardware - Others
Makita 6935fd doesnt go into impact mode, just stops like a normal screwdriver. Both batteries tested 15 plus volts. any answeres?
could be a problem with the impact hammer, I would suggest removing the front housing to make sure not sticking or hung up on the anvil. Make note of how you remove the gear housing to you can reassemble. Also you might want to go to makitausa.com first and download a breakdown for the tool
Nov 08, 2011 | Makita 6932FDWDE 14.4V Impact Driver
My impact driver doesn't ingage acts like low battery but have charged them,will screw in a screw and then stop instead of going into the impact mode
Likely to be weak battery due to end of life. Test battery voltage with meter right after charge , then again after use then stop. If voltage changes /drops, battery is worn out. If battery has full charge, check the condition of the battery contacts within the driver. Pull out the battery and look inside. The contacts should look bright and shiney. If dark, may need to replace them, but suspect that the switch is also bad. Good luck.
Sep 26, 2011 | Makita 6935FDWDE 14.4 Volt Nimh Cordless...
Btd144 when pull trigger light flashes drill dont go
The battery itself has a deep discharge protection .
Or the electronic or the battery its a new
phenomenon where you can have bought electronica and a triggerswitch and you have measured the electric field on 0.3 ohm on both 2x3 coils and the battery measured on maybe 15 Volt and it do not give nothing yes the lamps burned , but there was not an charger in my case delivered so i am also waiting for this problem by a Makita Jigsaw because a colleague has allready a electronic circuit and switch ordered and tried with that battery and an other battery but no life at all, so a new battery should may be working. or a broken or new damaged electronic part was delivered. that brushless tools are a young technical thing, many brands have.
the teething problems out, by the switches and the power mosnfets(panasonic) Makita is new for me this comparable problem a have also have yesterday.
next week i know more about a possible solution.
Makita BTD144 Lithium Ion Impact Driver Brushless Motor Parts
Sep 09, 2011 | Makita BTD144 18Volt LXT LithiumIon...
I have a 18 volt makita cordless impact driver i can not get the driver bit out it seems to be stuck in the chuck very tight
Try holding the bit with pliers and running in reverse, maybe with a shot of oil. That might free it up. You can also try tapping it (firmly) on the side of the bit
Aug 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
My 14.4 volt impact driver just buzzes when you pull the trigger and I can't figure how to get it apart
fist is the battery good, if it is then I would go on line to Makita and look it up for specs
Aug 16, 2011 | Makita 6935FDWDE 14.4 Volt Nimh Cordless...
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
Mar 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
185 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
