Question about Dictaphone 2750 Desktop Cassette Transcriber / Recorder
Lost manual for dictaphone 2750
Where can I obtain a manual for dictaphone 2750.
I haven't used the dictaphone for a few years and I need to know if the parts are all there?
  • Tasha333 Mar 16, 2009
    Thank you. I have all the parts except the power supply and the little
    phone line cords that connect everything.
    So now I will search for those.  Thank you again.
  • 43 Answers
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
Posted on Mar 13, 2009
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
Aug 12, 2011 | Dictaphone 2740 Desktop Cassette...
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Aug 24, 2010 | Dictaphone 2750 Desktop Cassette...
Foot pedal does not work for my Dictaphone model 2750 Where can I purchase a replacement
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Apr 30, 2010 | Dictaphone 2750 Desktop Cassette...
Necesito el diagrama electronico del Dictaphone 2750. Tengo una falla del circuito y necesito el diagrama para poder detectarla. No me llega tension al motor. Gracias. Herberth
Sorry, I don't speak spanish, but try replacing Q609 on the main PCB. It's located on the top, towards the front of the machine.
Also make sure that the motor doesn't have a 'flat spot' (that it stalls). This is generally what blows the Q609 transistor. If you have power to the machine and a cassette in, try manually turning the motor to see if it'll start on it's own.
Apr 20, 2010 | Dictaphone 2750 Desktop Cassette...
How to transfer voicemail onto cassette tape using Dictaphone 2750
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
Apr 05, 2010 | Dictaphone 2750 Desktop Cassette...
NECESITO DIAGRAMA PARA DICTAPHONE 2750 DESKTOP
Hola en realidad no tengo el diagrama pero you te recomiendo que verifique la tableta pricipal por la parte posterior normal mente es muy comun una de las venas del trasistor se fracture observe cuidadosa mente por la fractura ya que si no te equivocaste al conectar el motor no creo que este danado el trasistor recuerda que el Modelo 2740 su motor es de 4 terminales la primera de lado izquierdo es negativo despues positivo sige A y despues B qae estos dos ultimos son para resitencia de velocidad variable 20K
Dec 22, 2009 | Dictaphone 2740 Desktop Cassette...
Necesito ayuda urgente si ustedes son tan amables de ayudarme se los voy agredecer yo necesito el service manual porque compre 10 dictaphone 2750 desktop tengo problema con tres de ellos porque el motor se...
Hola Soy Tecnico en servicio de SONY y Dictaphone Y estas en lo correcto el modelo de Dictaphone 2750 Stadard cassette uno de sus problemas es que si la unidad queda con el cassette dentro y sin seleccionar auto encendido el motor queda funcionando asi que se muere mas rapido la verdad es que necesitas remplazar el motor y el motor solo tine dos cables asi que no es mayor problema el remplazarlo te puedo dar un correo para que solicites el motor normalmente esta compania no vende partes solo da el servicio de reparacion de las maquinas pero puedes decirles que Javier te recomendo para comprar estos motores que nececitas, despues de remplazarlo tus maquinas quedaran bien otraves email to service@tvps.com
Nov 30, 2009 | Dictaphone 2750 Desktop Cassette...
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
I lost the code to unlock my sony ericsson w600i. I haven’t used it in over a year and now I can’t open it.
You need the code PUK (PIN Unlocking Key). You have to call your operator to obtain it.
Jun 22, 2008 | Lands Phones
Dictaphone 2750 Desktop Cassette Transcriber / Recorder Logo
523 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
NOEL
NOEL
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
