Question about Hotpoint HSS25GFP Side by Side Refrigerator
Frost on the back wall of the freezer, refridgerator not all that
Alright, I ended up paying someone to fix this, and just about anyone can do it. Pull EVERYTHING out of the freezer, there are two quater inch sheetmetal screws that hold the back panel on that has frost on it. Remove them and the back panel. WOW LOOK AT ALL THE PRETTY ICE! Grab a hair dryer and go to work, thaw it all out and have a towel or shop vac handy, Mamas floor is gonna get wet. Turns out there is a defrost heater here that keeps the coils free from frost, kit number WR23X10467, in my case HSSGFT. If you have to order it, you can throw it back together and it should run for another week before it freezes up again, hopefully your parts will be in by then, just don't loose your hair dryer!
    Guru:
  • 462 Answers
Ok I see after 30+ years someone gets it. Beware though other things besides the heaters can cause the same simptom. Sometimes things are not as simple as they seem. And the question begs to be asked "Do you know if there isa reason other than defective heater that caused the heater to "burn" out? Like there may be a heater safety switch that should considr rteplacing as well, if it isnt working properly the heater will saty in too long and burn out your  new one prematurly.
Posted on Mar 19, 2009
I need to disconnect my ice maker from my GE TBX18DI refridgerator has anyone done this?
You should be able to reach behind the ice maker and unplug it from the wall.
Nov 27, 2012 | GE J Series 18.2 cu. ft. Top Freezer...
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE Refridgerator that is running but is not putting out cold air in either side (freezer or Fridge). We brought some items up from the downstairs freezer and put them in our the Freezer side of...
It is possible that the evaporator coils are not defrosting. Check to see if there is frost buildup on the back wall of the freezer. With GE's the defrost element is usually what causes them to not defrost and you can probably get it fixed for about $150 to $200 depending on who you use. Most appliance company's have a diognostic charge that runs anywhere from $40 to $80 to estimate how much it would cost to fix it. If you do have frost buildup you can unplug it and let the frost melt, and this will give you about a week before it stops cooling again. Hope this helps
Jan 30, 2011 | Refrigerators
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Refrigerators
Frezeeer works fine. Refridgerator (top) does not
good morning,
with this unit there are two issues that could be cusing this...
check to make sure you can hear the fan in the freezer,
2nd check your back wall for frost, sometimes this model ices up in the air chanels, to know for sure you will have to remove both the walls and the back wall, it takes a lil time but it can be done with only a screwdriver,
once you get the back wall off look up in the corners, of the freezer, it there is frost or ice blocks , remove those and reassemble you should be ok
make sure the drawer is closing properly
Oct 23, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
Frost in freezer and no cooling in refridgerator
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. You will have to remove the back metal wall. Look at the heater. It will be at the bottom of the freezer behind the back wall. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Sometimes on a circuit board. If nothing else defrosting the back of the freezer will make the ref work another week or two. Searspartsdirect will have the parts and schematics. I hope this helps, Jeff
Jun 08, 2009 | Whirlpool Refrigerators
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Amana Refridgerator - Freezer problems
here's what you can check,defrost timer,put frig. out and listen to see if compressor is running,freezer fan listen to see if fan in freezer is running,look to see if you have frost on back of freezer wall,your defrost heater might be bad,also there is a thermonator in the freezer that turns heater on and offhope this help-mike
Jun 02, 2008 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
129 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
