Stopped cooling but blower/fan still works. - Heating & Cooling
    Problem Solver:
  • 10 Answers
Make sure Condensor coil ( radiator type) is clean. But other than that it will cost more to fix than just to measure up opening and slide a new one in place.NOTE: wash with water is ok .WARNING!! - unplugg or turn breaker off.
Posted on Apr 21, 2013
Locate the blower motor resistor on a 1999 dodge durango
most resistor blocks bolt to the fan housing, be causes its air cooled
and must be near fan actual so it always is cooled. see?
i just looked,its there. dead center blower case.(fsm book)
alldata.com
log in and read the HVAC pages.
if fan fails on high too, its not the resistor, because on high
it bypassed.
ah but not if the thermofuse in the resistor block is blown
Jul 04, 2014 | 2004 Isuzu Rodeo
A/c stopped cooling a couple of weeks ago and now the blowers have stopped working too What could be the problem,all fuses are ok.
For the ac to stop working either the compressor clutch is not getting power or the gas is too low so the low pressure switch has switched the compressor off to stop sucking in air through the leak. The blower is controlled by the fan switch which is a 3 positional switch that has a resistor for each position. These resistors have a habit of burning out so the fan will not work. The resistors are in a block located in the blower housing. So you have two faults to fix.
Aug 31, 2013 | Mitsubishi Colt Cars & Trucks
AC has stopped working. CT3500 thermostat. Had "replace battery" indicator on. Replaced batteries with fresh new ones. Now the blower is not working when AC is on. If I set the thermostat to Fan ON,...
Possibly - the fan is supposed to work in conjunction with the compressor. Otherwise the evaporator will freeze up.
Check to see if the thermostat can be reset to factory defaults because it definitely is not working right.
Sep 14, 2017 | Honeywell Heating & Cooling
2002 acura running hot, Cooling fans are not comimg on and blower for A/C heater not working
Test both the cooling fan relay and the fuse (located under the hood and inside the control module box).
For the inop blower fan, test the switch if the fuse checks out.
Apr 11, 2013 | 2002 Acura RSX
How do you perform an electical test on the "automatic fan switch" in a Williams wall furnace blower accessory? Part number is P-322395. Everything else including the two-speed switch and fan...
disconnect power from fan. use an ohm meter should be open when cool and closed when hot. you can do same with 110v but be carefull. 110v to one side when cool and 110v on both sides when calling for fan.
Feb 09, 2011 | Heating & Cooling
2000 Olds Alero. Cooling/Heating fan stopped
The blower is on the right hand side under the dash. You are right in thinking the blower resistor is the problem. The resistor is in the heater box behind the blower. Only 2 bolts hold it in but the back one can be a challenge to remove. The bolt is 5.5 mm.
Check for power and ground with a test light at the resistor connector. You should have power on the colored wires in the various switch positions. The black one is ground.
Aug 10, 2009 | 2000 Oldsmobile Alero
My cooling fans and blower have stopped working on '89 Ford probe turbo; all fuses are Ok.
Do you have the twin cooling fan set up?one is for the engine and the other is for the AC.these can be replace through the aftermarket parts stores. The blower for the heat/ac can be replaced. You can also test these units if your unplug them from the harness,and use jumper wires to supply power and ground.
Jul 24, 2009 | 1989 Ford Probe
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
