Question about Jamo SUB 250 Subwoofer
I have a Jamo Sub 250 Its been great until today. It made a small pop noise. It no longer turns on. I removed the back of the sub and it appears to have damage to two of pieces on the main curcuit board. Can this be repalced at a reasonable cost or do I just buy another sub? And where do I Get the part if fixable?
  • 238 Answers
SOURCE: Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Posted on Jan 12, 2008
sanjin
  • 56 Answers
SOURCE: I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Posted on Mar 18, 2008
  • 151 Answers
SOURCE: JAMO SUB 650
The jamo sub is a fine buy but also look at subs from REL as they can hit hard when needed and are great for music.Now on to your amp,look round the back and you should find a socket marked sub pre out,plug a sub or phono lead into this and then into the input on the sub,this could be marked in or line in,turn up the volume or gain on the sub and also make sure you have the sub turned on in the speaker settings in your amp.
Hope this helps.
Cable guy.
Posted on Jun 27, 2008
  • 127 Answers
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Posted on Mar 03, 2010
  • 127 Answers
SOURCE: cant connect jamo sub 250 to marantz SR4001
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
I have bought JAMO sub 250 subwoofer and Pioneer VSX919AH-K amp. Please advise how can I connect them. The amp has one RCA out for sub but the sub has two line in sockets (left and right). Do I need to use...
Dec 30, 2009 | Jamo SUB 250 Subwoofer
Cant connect jamo sub 250 to marantz SR4001... how do i do it? any suggestions?
Sep 27, 2009 | Jamo SUB 250 Subwoofer
I have a jamo 250 sub and dont know which coax input to use
one will do just fine if you've tried one and its not working try to refer to manual on how to set up in the receiver function menus and if the sub is powered by an external amp which most are
Jul 03, 2009 | Jamo DVR-50 System
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
Jamo 250
Jan 11, 2008 | Jamo D 4SUB Subwoofer
Jamo SUB 250 Subwoofer Logo
107 people viewed this question
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
