Question about Nintendo Wii Console
What is the value of varistor sitting beside the fuse of Wii power supply? I have a blown fuse and burned the varistor as well. I need to replace the varistor but dont know the value of it.
Wii varistor value beside the fuse?
SOURCE: wii power supply
To reset the AC adapter you need to unplug it from the wall outlet and the Wii console and wait at least two minutes. Plug it back in and it should come on. If you have it plugged in a surge protector with other appliances, the other appliances may be interrupting the adapter, causing the power to go off.
Posted on Dec 12, 2008
jyackle5
  • 8197 Answers
SOURCE: my wii won't turn on and there is no red light.
You could reset the AC brick by unplugging it from both the wii and the wall outlet for 90 seconds.
Posted on Mar 12, 2009
  • 3 Answers
SOURCE: wii will not turn on.
Unplug power from BOTH ends for 2 full minutes, then reconnect. Red light should be back, and it should work fine. Let me know!!!
Posted on Apr 24, 2009
  • 21 Answers
SOURCE: Wii power supply problem
I would buy a used/new one from the game store. If lightning got it, it's going to have fried more than just a "fuse".
Posted on Jul 26, 2009
  • 1527 Answers
SOURCE: my wii blew a fuse and i want to know what to look for
hello the fuse inside is made of glass if you open the wii up you should see the power supply the fuse might have a cover over it, if the fuse is black it's blown, if you put a nother 1 in and blows again the then you have a dead short somewhare make sure the power off. good luck.
shaun
Posted on Nov 13, 2009
Pioneer radio /receiver VSX-D457 I had a power spike at my house there's no red light on no power is there a fuse inside ?
There are general several fuses inside receivers. First look for them and if they are blown then also look for a blown MOV (Metal Oxide Varistor(s) that is blown on the power input side. It should look visibly burnt in most cases. They look like ceramic capacitors but measure different and they are only in the power supply area of the unit. A good varistor will have no measurement either way on the 10K Ohm scale on a Digital volt meter. There are many different ratings for varistors but get one about the same size with a 470v rating and you should be ok.
c224badf-bb9e-44b3-ae5d-5ef5af040d88.jpg How to Test Metal Oxide Varistor eHow
Apr 04, 2014 | Audio Players & Recorders
Casiotk2700 with vs1 blown on main pcb
It sounds like the varistor on the power supply rail. this always gives trouble. Cut it out and replace the fuse if blown. Turn on and all should be well
Dec 30, 2011 | Casio Parts Cash Register PC Desktop
The power went out and now the wii wont turn back on?
HI. this is a power supply issue. Your unit is equipped with an external power supply unit. This box incorporates all the necessary AC current regulators, and transfer agents to run the Wii. There are ,also, some protection circuits as well. These are in place to protect the unit from surges are unstable AC spikes as well. There is a fuse that is located inside the power supply box. Simple unplug the power supply, and gain access to the fuse, by removing the outer cover of the power supply unit. there are a few screws,(on the bottom), that hold the top cover. remove the screws, and open the power supply unit. this will expose the fuse. Kindly, inspect the fuse. if it shows signs of trauma, and it is blown, simply replace the fuse.
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap.
Feb 08, 2011 | Nintendo Wii Console
No power fuse blown replaced fuse new fuse blown
It shows that there is shorting in the further circuit,check MOV (metal oxide varistor) used for protection in the mains supply,MOV is mounted parallel to the main input supply,if o.k check further bridge rectifier and finally switching device used for SMPS power supply either transistor or STR by replacing the same.
Feb 04, 2011 | Emerson TS1997 19" TV
MY Wii Console wont power up and everything is connected?
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap...
Jan 28, 2011 | Nintendo Wii Console
Wii wont power on
Now, if the fuse shows no signs of trauma, or burn marks, this will confirm power supply circuit failure. This will require that you replace this damaged power supply unit asap.>>
Dec 27, 2010 | Nintendo Wii Console
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
Microwave oven blowing 20 amp ceramic fuse
Chances are if the varistor fails, it fails drastically causing a short circuit across the supply. It will sit across the supply (it will look like a thick ceramic capacitor) and you can check for continuity after isolating that at one end. If it shows low resistance (it should show almost open circuit with a Digital meter), replace it.
It need not be the culprit. If you are familiar working with High voltage circuits ( they are lethal inside a microwave ovens as the current capability is high here), you can discharge the doubler capacitor and isolate the high voltage diode to check for shorts in the HT area.
Mar 18, 2009 | Microwave Ovens
GE Spacemaker Microwave Blown Fuse replaced still no power
If you measure across the varistor leads with it still in the circuit, you should measure around 100-300 ohms, which is the DC resistance of the primary of the low voltage transformer.
If you read infinity / open the primary of the low voltage transformer is bad.
If the varistor is bad, it will be shorted and usually it will be cracked or split. This is a much simpler way to test the varistor.
Have you checked the magnetron thermal cutout (TCO) (or thermostat if so equipped) and the oven TCO? These are the leading causes of a dead GE when the fuse is okay.
You didn't mention the model number. What is it?
Please reply back here if you still need help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Microwave Ovens
Instantly blows the 5 amp fuse next to the power cord plug.
You have a short in the power supply. Look at the regulator and or rectifier diodes. These are all on th primary side of the SMPS (switched mode power supply) the secondary side if shorted shouldn't cause a blown fuse at all.
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Nintendo Wii Console Logo
81 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
