Question about Bunn Coffee Makers & Espresso Machines
Bunn coffee maker
Does not wait till lid is closed for water to start coming through machine.
  • 22 Answers
Some of the coffee makers doesn't come with that feature.
Posted on Jun 29, 2014
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
  • 131 Answers
SOURCE: Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Posted on Feb 13, 2009
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: Bunn Coffee Maker Leaks out the bottom
Hi I have had this problem twice....this time I took off the top of the maker to check it out and noticed something loose and this fixed the problem, on mine at least. Lift the lid and take out the two Phillips screws, and remove the grid. Take out the three (or four) Phillips screws on this level and remove the top of the maker. There is a tube, with a hex nut around it, under the swivel arm that shuts off the water when the lid is up. On my maker this nut was very loose, even though the seals were still good. I tightened it with a pair of pliers( don't over tighten) and it hasn't leaked since. I also cleaned the water tray out while I was at it , as it looked rather yechhy. Reassemble and put the screws back in (don't over tighten, as they are in plastic)
Posted on Mar 31, 2009
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
Will not brew
Make sure the coffee maker is full of water. Keep filling it till water comes out of spray head.. Should take two full pots plus 3/4 of another one. Wait for water to stop coming out of spray head. Now the unit should be ready to brew after it heats up.
Mar 29, 2013 | Bunn VPR Coffee Maker
SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
Grx Bunn coffee brewer will not brew. I've followed all directions carefully. I've waited almost 30 min for it to heat up I've added more water and still nothing. Now I have been waiting for about an hour...
It sounds like the tank isn't full. It takes 2 full decanters of water to fill the tank in the bank. After pouring in 10 cups of water, close the lid and wait 3 min. Then open up the lid and pour in another 10 cups of water and close the lid. Then turn the vacation switch on and wait 15 min. Now you are ready to brew coffee. Place your grounds and filter in the funnel basket and pour in 4-10 cups of cold water and place decanter on warmer plate. Close the lid and in 3 min you will have a pot of coffee. If this doesn't happen, please call 800-352-2866 and we will be happy to assist you.
Jun 17, 2010 | Bunn GRX-B
How do we use the Bunn ..... it was given to us with no manual
The water is poured into the top lid and then swivel the lid closed. The brewed coffee will come out of the bottom of the funnel basket into the glass decanter.
Jun 09, 2010 | Bunn NHB Coffee Maker
Have a Bunn NHB. I cannot get more than 4 cups of
I work for BUNN. Has your issue been resolved? The rocker arm is inside the pour in bowl (where you pour in the water for brewing). To get to it you have to take off the entire top lid (not just the spin lid above the pouring area). That can be removed by lifting it up and then you simply snap it back on when you are finished. Hope this helps.
Jan 03, 2010 | Bunn NHB Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Waterflow begins before lid is closed
thats why it came with a plastic pitcher
Nov 16, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
