Question about Kenwood Kac-m846 4/3/2 Channel Amplifier Car Audio Amp
Where do i connect my subwoofer speaker on the amplifier Kac-m846
  • 136 Answers
SOURCE: connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Posted on Sep 03, 2009
  • 5 Answers
SOURCE: I recently purchased a new Kenwood KAC-9104D 1800
You should check and verify first the output signal in the amplifiers by using a multimeter on the db range, this is to identify good output of the amp. After that check the polarities for correct wire orientations.You should connect the speakers one at a time to check.
Posted on Jan 16, 2010
  • 306 Answers
SOURCE: How to connect Kenwood KAC-6104D to a single 4ohm
you want to parallel the terminals on the woofer. a jumper from positive to positive and the same on the negative will equal 2 ohm load at the amp
Posted on Feb 07, 2010
  • 506 Answers
SOURCE: I need an appropriate speaker
This amp is stable down to 4 ohms bridged at 120 Watts or 2 ohms stereo at 60 Watts X 2. If you are going with the bridged mono hookup just make sure the impedance of your subwoofer is no less than 4 ohms. A good rule of thumb is to be at least double of what your amps rated output power is. So if your amp can put out 120 Watts into 4 ohms then get at least a 240 watt subwoofer.
Do not exceed the rated load for your amp, you will damage it. Here is the datasheet for your amplifier
http://manual.kenwood.com/files/B64-3031-00_En.pdf
Posted on Jun 12, 2011
  • 689 Answers
SOURCE: Which speakers (Front/Rear) to buy that match Kenwood KAC-M846 4/3/2 Channel Amplifier.
I don,t no where you are reading thease articles from,I installed car audio equipment for over 40 years, Untill i retired a couple of months ago, Who ever is writeing those sort of articles does not have the slightest clue what they are talking about, It is the opposite way around, It is allway better for yor (Speakers) To handle more power then what your amp puts out, Then you will not blow the spaekers, It is best to get speakers at least 20 watts more then what your amps maximuin (RMS) Watts are, Hope this helps you out, (PS) 50 watts (RMS) Is what most people go for, It is in no means (Under) Powered.
Posted on Nov 06, 2012
Testimonial: "Rob cleared the cloud of confusion and shared his wisdom and expert know how about car audio amps and speakers."
Nov 05, 2012 | Kenwood Kac-m846 4/3/2 Channel Amplifier...
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
Hookig up two single voice coil subs to a kentwood kac-9104d class d mono amp
connect up the woofers in parallel. Will give you a 2 ohm load.
In other words. Connect both positives together on each sub and both negatives together on each sub. Then connect to amplifier.
Aug 12, 2010 | Car Audio & Video
I have a craig powerplay amplifier model # V 502 48 watt. i need wiring schematic.can you help ?
From left to right your connections will be as follows:
BATT: 1x solid (at least 4mm in thickness) wire directly connected to your car battery positive(+).
GND: Will be an earth wire of the same thickness connected to any section on your vehicles body (chassis). Even a seatbelt bolt will do.
P.CON(REMOTE) will be the remote wire coming from your radio (normally blue or orange in colour).
The speaker connections are pretty straight forward unless you are going to connect subwoofers.
At the back:
FILTER: leave off unless you are going to run subwoofers
OPERATION: Leave it on sterio unless you are going to run subwoofers
LINE IN: Will be RCA cables coming from your radio
SPEAKER LEVEL INPUT: is for connection if your radio does not support RCA jacks
Please feel free to ask about anything you are unsure about. I hope this helps and solves your problem
May 20, 2010 | Kenwood KAC-5201 Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
I recently purchased a new Kenwood KAC-9104D 1800 amplifier. I hooked it up just as I had with a previous amplifier but it wont power the subwoofers. When one of the RCA cables is plugged in and the other...
Jan 16, 2010 | Kenwood KAC-9104D Car Audio Amplifier
Can i connect 4 speakers and asub to a kenwood kac m645
There is many amplifiers made for that purpose. They'll have 4 channels for your mids and highs and a mono channel for your sub. I looked up the specs for that model and based on what I saw I wouldn't recommend it.
Nov 22, 2009 | Car Audio & Video
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Kenwood Kac-m846 4/3/2 Channel Amplifier Car Audio Amp Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
