Hotpoint WMA44 Front Load Washer Logo
Posted on Apr 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor? turns on okay, water fills up barrel and then as the moter starts it cuts out and ends cycle with the water left in
prem mathew
Level 3:
  • Hotpoint Master 662 Answers
  • Posted on Apr 21, 2013
prem mathew
Hotpoint Master
Level 3:
Answers
662
Questions
Helped
265459
Points
1748
The problem could be with your pressure switch. Click for help on this site regarding change/check of hose connected with pressure switch. Enter your brand and model number of machine.
2 Related Answers
Anonymous
  • Posted on Sep 22, 2008
SOURCE: Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
A
Anonymous
  • Posted on Sep 27, 2008
SOURCE: Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 • Home
3helpful
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
1helpful
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
6helpful
2answers
GE washer does not agitate or spin
There is a fusable link that is known to blow. The replacement is available. Open the front access panel, Remove the tape from the wires that are taped together near the top of the wiring harness,about 3/4 of the way up. You will see a wire that is covered with shrink wrap (White with Red stripe I think) Cut it out, check for open circuit with an ohm meter. If it is open, (no continuity) Replace it. I used a regular piece of wire as a jumper for testing till I got the new fuse. The fuse kit I got comes with 2 of these fusable links. One is for a spare.
2answers
Simpson enduro 701 washing machine
After the water pumps out on each of the cycles the spin does not go or start and it gets stuck there.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
