How can u tell your motherborad is bad - Computers & Internet
  • 27,725 Answers
Disconnect the power cord form the power supply, be sure the power supply is set for 110 or 220 volts depending on your location and power and double check it (most have a 110/220 switch) Feel/look at the back of the power supply to determine if the fan is working. http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm If the fan is working, try another power supply anyway. Plug the computer directly into a known-good (a lamp works) power outlet Check to be sure you do not have a motherboard stand-off in the wrong position and shorting-out the bottom of the motherboard. Inspect/shake and listen for loose metallic objects (loose screws) on top of and under the motherboard and in expansion board slots. Look carefully at the ISA and PCI slots, see if any of the contacts got bent/shorted-out. Sometimes an expansion board will dislodge one and it will be pushed into the bottom of the slot. Inspect the motherboard for broken or burnt components. Carefully inspect the motherboard for black soot from bad bearings and clean and replace the culprit. Look for bent/shorted pins on the motherboard headers and straighten. Be sure the speaker is plugged into the motherboard. If you hear beeps. Decode the beep code. If not, double-check all jumpers. Push down on all chips that have sockets in attempt to reseat them. What CPU are you using? Be sure the core voltage is correct. Be sure the CMOS battery jumper is in the correct position. Some distributors purposely ship motherboards with the jumper in the wrong position. Find the jumper that clears the CMOS, put it into the clear position for several minutes, put it back in the normal position, plug-in the power cord, and push the power-on button. If you apply power to the motherboard with the jumper in the clear position you may damage the motherboard. Pull all boards except video. Disconnect all cables going to all drives, pull all cables except power, power on, and speaker, connect the power supply to the motherboard (the black wires go in the middle on AT power supply connectors--"Black OK, red your dead"), reseat the memory, plug-in and screw-down the display adapter and nothing else (push down on the top, front of the adapter and make sure it is properly seated by looking at it all along the PCI or AGP connector), connect the power-on switch and the speaker. Check the monitor plug for bent or pushed-in pins, connect the monitor and nothing else. Check the monitor power cable. Reseat/replace the memory. Check for Motherboard Electrolytic Capacitor Failures Check the CPU for bent pins. Try another processor. Note: If you apply power to a motherboard with an Athlon or Duron processor without the CPU fan connected, even for a few seconds, you will fry it (see http://duxcw.com/digest/guides/cpu/socketa/heattip.html). Check the CMOS battery with a multi-meter. Should be around 3 volts (2.8 is ok). Try a different video board. See if the CPU and memory will work with another motherboard. Pull the motherboard, set it on the box it came in, install video, memory, CPU, power, and power on. See if it boots. I have seen several instances where this works when the board will not work in the case. And, when reinstalled in the case, it continues to work. I have also seen where it didn't work out of the case immediately, but did work the next day and continued to work. One of those mysteries. Temperamental computers with minds of there own. Replace the motherboard.
Posted on Apr 21, 2013
How to remove motherborad out dell 560 inspiron pc
www.dell.comclick technical supportclick support for home usersin the far-left column, look for the link "manuals" and click on it.click "choose from a list"click desktopsclick inspironclick inspiron desktopclick 560MT unless you have the 560ST.click confirmpick a language
Feb 03, 2012 | Dell Computers & Internet
Mercury PI 915 GLM Express motherborad Drivers i need
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Dec 11, 2010 | Mercury Computers & Internet
Biostar TA780G M2+ turns on and alll the fans turn on but it doesn't POST. Any Ideas Thanks
Hi;
do you hear the bip sound of BIOS ?
you should to discharge your motherborad, deconnect all, the power supply, the CPU, the CMOS battery the HDD and remove the motherborad, with contact cleaner clean properly your motherboard wait fo 2 hours and reaasemble all and try again.
Oct 30, 2010 | Computers & Internet
Components broken off
the pci and pci-e system needs a min of 2100 mf to 2400 mf
lala linda
May 30, 2008 | MSI : P4MAM2-V (7095-010)...
Motherboard Driver
hi frined
tell me *********** board model no so i can help u batter
Mar 31, 2008 | Computers & Internet
Install motherboard drivers for the first time
If you have a genuine copy of XP then it should boot from that and install it. If it's not booting from that you may have to change the boot priority in the bios, the motherboard manual will tell you how to enter the bios and make and save changes.
Are you sure it's not trying to boot from the hard drive.
As for the motherboard drivers they are installed after you put XP on.
If it's not reading the XP CD properly you may have a bad CD or CD Rom.
Mar 13, 2008 | Televison & Video
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
