Question about Samsonite Suitcase Bag Dog Cat Pet Carrier Black Zippers Pocket 10 X 11 X 18"
HOW TO CHANGE THE CODE ON SAMSONITE SUITCASE
HOW DO I CHANGE THE COMBINATION ON A SAMSONITE SUITCASE CANT SEE A LEVER ON THE OPENED LOCK TO ADJUST
SOURCE: change luggage key combination
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Posted on May 05, 2009
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
I have Samsonite suitcase with the lock type B. When I used it last time, it was working. Now the code system doesn't work at all. I carefully followed the instruction to lock it but the code doesn't work,...
did you do this...
STEP 1 Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2 Locate the reset button, usually placed to the side of the combination dials.
STEP 3 Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4 Release the reset button after you set the numbers to the new combination.
STEP 5 Test the combination by turning the dials to the new code to open the lock.
if you did this then I'd contact Samsonite Customer Service at 800-765-2247.
Happy New Year
Jan 01, 2018 | Health & Beauty
Nov 08, 2009 | Samsonite Tripod
Oct 16, 2009 | Samsonite Tripod
Apr 11, 2009 | Samsonite Tripod
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
Samsonite Suitcase Bag Dog Cat Pet Carrier Black Zippers Pocket 10 X 11 X 18" Logo
54 people viewed this question
Top Samsonite Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Samsonite Pets - Other Expert? Answer questions, earn points and help others
