Question about Acer Aspire 5742-7620 Core I3 Processor 500gb Hd 4gb Ddr3 Ram Win 7 Home Premium
Why will windows not load after recovery?
After installing e recovery on new hard drive and after system reboots windows will not load.
  • 40 Answers
If you made recovery with f11 taste and don't boot your hdd is gone
Posted on Nov 13, 2013
How do i reboot my laptop fujitsu siemans alimo pro without disks? does this restore all hardwear & softwear?
First a rebot is just shuting down all running programs the starting them back up, Reboot is the same as Restart. You perform this by clicking Start then Restart. The second part of your question about Restoring is called System Restore And that is done differently depending on your Operating System. In Windows 7 just click Start then type System Restore then hit enter and System Restore will start and you can follow the steps from there.
In Windows XP click Start then click Run then in the Run Box type msconfig and hit Enter yoir System Configuration Utility should then popup and you just click on LAUNCH SYSTEM RESTORE near the bottom of the window. You should then be able to follow the directions.
System Recovery is sometime another option, Which you may or may not be able to do.You can perform a System Recovery on many computers. This will return your hard drive to the ORIGINAL factory configuration, with everything it originally had. First, find out if your computer supports this option
NOTE: SKIP THIS STEP IF YOU CANNOT LOAD WINDOWS.
Go to My Computer, and look under Hard Disk Drives. A lot of PC's today will include two hard disk partitions. There is always a C:\ drive (normally the Windows drive) and often a D:\ drive. The D:\ drive may be called "Recovery" or something like it.
If there is no D:\ drive, you may have to do System Recovery from a disk. Contact your PC manufacturer to order the disks. It's easier than buying a new PC.
WARNING! SYSTEM RECOVERY DELETES ALL FILES YOU HAVE CREATED AND PROGRAMS YOU HAVE INSTALLED. It restores the hard drive to its original state, This means that all files you have created are DELETED! Including Installed Programs! You MUST backup anything you want to keep! Backup utilities are installed with every version of windows.
Now to perform System Recovery. Restart your PC. As Windows is loading, look for a message that says "Press [KEY] for System Recovery". When you see this message, press the given key and follow the instructions, sometime they flash so quickly you cannot hit the key in time if this happens just restart and since you know which key this time be ready and hit it when it flashes, hopefully you will be able to perform a successful System Recovery.
NOTE:
In Windows 7 you can Start system Recovery the same way you did System Restore just type Recovery instead of Restore
If you do not see this message, but see other messages, try pressing them. Example: "Press [KEY] for Startup Options".
Jun 08, 2011 | Computers & Internet
I just installed a new power supply and now i get a message saying cd rom priority...no medium i then stat it up with my recovery disk it asks what language and that it will reboot the system to factory...
Installing a new power supply should not involve any recovery process. You may have corrupted the hard drive some how prior to the power supply going out. And, if it has taken a significant amount of time to process the recovery, the recovery partition in the hard drive may have been affected as well. You're probably going to need the actual recovery disc to reformat the hard drive - chances are the hard drive is just corrupted and is still good.
Jan 08, 2011 | Dell Computers & Internet
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
My windows is corrupted how to load new windows with external drive
You have to boot to the BIOS and enable USB start up.Then reboot with you drive plugged in.
Apr 17, 2010 | Acer Aspire One PC Notebook
Recovery Disc will not load OS on HD
laptop panasonic toughbook bios password pro
Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
1. Boot the computer using the XP CD. You may need to change the boot order in the
system BIOS so the CD boots before the hard drive. Check your system documentation
for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery
Console, press R", (you Do Not want to load Recovery Console). I
repeat, do not choose "To repair a Windows XP installation using the
Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows
installations.
5. Select the XP installation you want to repair from the list and press R to start the
repair. If Repair is not one of the options, END setup. After the reboot read
Warning
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any
key to boot from CD when the message appears. Setup will continue as if it
were doing a clean install, but your applications and settings will remain intact.
Apr 05, 2009 | Computers & Internet
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
Assist with an Operating System start issue? PC is a Gateway GT5228
the following will re-install windows without destroying your stuff but you must follow it exactly !!!!!!!
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" height="21" alt="To setup Windows XP now and Repair Install , press ENTER." src="http://www.michaelstevenstech.com/note.gif" width="15" border="0" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  7. good luck beergut707
Oct 09, 2008 | Computers & Internet
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
Acer Aspire 5742-7620 Core I3 Processor 500gb Hd 4gb Ddr3 Ram Win 7 Home Premium Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
