Cct diagram of cs3000 amp - Audio Players & Recorders
  • 15,950 Answers
Echo cs3000 won't start push down on purge bulb it stays down
Fuel filter may be blocked or you have the hoses round the wrong way if it has 2 hoses
Apr 08, 2014 | Echo Shock Mount Cs300 Cs3000 Cs341 Cs360...
It's a Kenwood VR-4080 the reciever turns on and works but has very low volume and amp sinks get hot reguardless of volume setting?
heat in amps =power or fault, since you have no power then its most likely the fault that is causing the heat, I would take it to my dealer or a good tech. Modern amps like these are very complicated, almost impossible to diagnose and repair without cct diagrams and service info. They also have potentially dangerous DC power rails.
Hope this helps
Thanks for using FixYa
Aug 13, 2010 | Kenwood VR-4080B Receiver
My Squier 15W practice amp has stopped working. I've ruled out the chance that the guitar doesn't work, I plugged it into my friends amp and it sounded fine. However when I turn my amp on, all I get is...
There is a good chance that the output stage (usually an Integrated cct) has been damaged - sometimes one supply fuse failing can cause this effect - checking inside the amp and looking at the main cct board will show some on board fuse (s) and or the main output IC - you could be luck and it is a common type that you can by at your local electronics supply retailer and just replace it - at these low powers the cctry is pretty simple - and simple to fix.
Feb 17, 2010 | Audio Players & Recorders
When Powering up from standby, it can take hours to switch on depending on the ambient temperature. I havent opened it yet and poked around due to time constraints but would prefer a CCT Diagram for when I...
well if you haven't opened it up and checked for cold solder joints yet,,,, i can see why you are no longer in the business. what the #%$& is a CCT anyway?
Jan 05, 2010 | Televison & Video
I have blown the protection circuit on my yamaha rx 600d amp anyone with a clue whats needed to fix?
Hi friend,when something goes wrong in the output of the amplifier the protection circuit take place to prevent further damage could cause by DC power such as speakers or other related circuits...I think in your situation either one or both output amp stage have blown,then the protection cct turned on (not blown protection circuit!?). If so you have to check all the output transistors for short cct, if shorted you must also check all the DC bias cct nearby such as small transistors,resistors...If you are not familar with amplifier it better to find a tech as all amplifiers need a very precide repair technic , If the DC BIAS were wrong , when you turn on the power it will blow straight away! All times and cost will be waisted!
GOOD LUCK!
Tan Ta
Nov 23, 2009 | Yamaha Audio Players & Recorders
F150 auto trnsm van abs flashing #9 code trnsm locked in park disconnect batt trsnm ok ?????? 1999 yr of van
checked out all the fuses had misplaced 1 when checking why no power to the radio and why abs light was on abs light is still on brakes work ok and trnsmsn works fine .still need a fuse box diagram for fuse cct id do not have owner's manual and haynes manual doe,s not give fuse and cct id .
ps:- it was fuse #11
Sep 08, 2009 | 1999 Ford Econoline
Ministry of Sound MOSTS072 ,NON rotation of all
no power glass fuse blown replace when i switch on fuse blows again
Mar 16, 2009 | Audio Players & Recorders
Ups
filter cct burn out so, kindly give e filtter cct of 800 apc ups.
Sep 16, 2008 | Computers & Internet
JVC VCR POWER SUPPLY DOES NOT START
Not many of us could help you, a quicker solution would be to Google your above question. " CCT Diagram+HR-J20ES/SA"
Jan 05, 2008 | Televison & Video
 Grubhead
Grubhead
