Question about Nikon D200 Digital Camera with 18-70mm Lens
EE NIKON D 200
What does EE mean?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Do you mean "fEE"?
You're apparently using a lens with an aperture ring. Turn the ring to its smallest setting (largest f/number). If the lens has an aperture lock, lock it. You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
Posted on Apr 20, 2013
Te 522 error EE
EE stands for Energy Efficient. The problem could be:
1) a bad thermostat 2) inadequate ventilation (blockage) 3) a bad controller board if the unit does not come on following this display.
The manufacturer pretty much decides what these specific codes mean. You might have to contact them.
Apr 07, 2015 | Heating & Cooling
What does EE code on lg dryer mean
The EE error code stands for "EEprom Error" which means that the main control board EEprom program memory is defective.
Replace the main board.
Feb 19, 2015 | LG Washing Machines
Displaying "EE" Code. Does not run.
the best suggestion is to contact the manufacturer at: (877)337-3639.
Jun 19, 2014 | Haier CPN10XCJ Air Conditioner
Shows ee and will not come on
EE is an error code. I cant help you with this one , but it means something has failed. Try the Fedders site or a Fedders Agent who may be able to state what the EE code means and then see if you can purchase or obtain a Tech to fit the part required.
Jul 03, 2011 | Fedders AEQ07FBG Air Conditioner
How would I enter the following on this calculator? 9.1 EE -31 ? 1 EE 3
Do it exactly as you wrote it. For the negative exponent use the change sign key [ -]. The question is whether you are aware of the meaning of the EE key.
The EE key is a shortcut for x10^. Thus 1EE3=10^3=1000.
As to the other number (the electron mass) its value is 9.1x10^(-31) kg which you enter as you typed it 9.1 [EE] [( -)]31 [=]
Sep 01, 2010 | Texas Instruments TI-30XA Calculator
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
HELP, I can't seem to figure out scientific notations with my Texas Instrument TI-30XA. I've searched for hours on the web. Here's the problem: 7.82 x 10^10 / 63.55 = 1.23 x 10^9. But when I input 7.82 x...
The error comes from the lack of understanding of the meaning of the notation used by the calculator manufacturers.
The [EE] is a "shorthand" notation for times 10 to the power of .
To convince you of it try entering
1[EE]0 [=] this is 1*10^0=1*1=1
1[EE]1 [=] this is 1*10^1=1*10=10
1[EE]2 [=] this is 1*10^2=1*100=100
When you enter 7.82x10[EE]10
you are calculating
7.82*10*1*10^10=7.82x10^11.
Hope it helps.
Nov 12, 2009 | Texas Instruments TI-30XA Calculator
What does the ee symbol above the qoutation mark mean
What you call a quotation mark is in fact a comma. It is used to separate arguments inside commands that require more than one arguments, or the elements of a list.
The [EE] that you access by pressing [2nd][comma] is very useful in scientific areas of studies such as physics and chemistry. It is a shortcut for times 10 to a power.
If you want to enter Avogadro's number you enter
6.02[2nd][EE]23 [ENTER]
The electon charge is
1.6[2nd][EE] (-)19 [ENTER] . Here the (-) is the change sign key located between [.] and [ENTER]
The [2nd][EE] sequence must always be followed by an exponent even if exponent is 0.
Try these
[2nd][EE] 0 [ENTER] (Surprised? You should'nt be!)
[2nd][EE] 1 [ENTER]
[2nd][EE] (-) 3 [ENTER]
Hope it helps.
Nov 04, 2009 | Texas Instruments TI-83 Plus Calculator
When I square 10 it equals 1000 when i use the EE feature
To raise 10 to the 2nd power, if you do not have a dedicated key, you use the (^) or (X to the y) or (Y to the x) depending on calculator.
The EE key is a shortcut. It has another meaning
EE 0 = 10^0 =1
EE 1 = 10^1 =10
EE 2 = 10^2 = 100
Thus if you enter 10 EE 2 this is equal to 10 x EE 2=10x 100= 1000.
This is the correct way.
Hope you will remember it : It is the source of much grief to the learners.
Oct 08, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Inputing Scientific Numbers
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
Nov 29, 2008 | Texas Instruments TI-30XA Calculator
Nikon D200 Digital Camera with 18-70mm Lens Logo
52 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
