Question about Sansui Vintage Au-517 Intergrated Amplifier - Excellent Condition
I have got a Sansui AU-X 517 R Stereo Amplifier problem face is about any one of the channel goes off with some scratchy sound after using the system for 10 to 15 mins and again works perfectly after few seconds such incidents happen offen when i connect any 3.5 jack MP3 music input
5 Suggested Answers
palaboy
  • 5807 Answers
SOURCE: Sansui AU-D77X left channel output transistors
the first thing the tech must do is to insure that there is no more than 2V on the base of the
pre-drivers of the driver transistors.
If it do then connect the pre drivers and monitor for:
a ) DC offset
a good amp never produce an over of 0.7V on its output
b ) measure the idling current , more than 80 mA is hazardous to your output
transistors.
Test and continue listening for a day.
( without the output transistors )
you can even series additional resistors on the emitters to be safe
( like 100 ohms on each )
Better if you can work and test the amp in about 1/2 of the AC supply.
( if your using 220V trim the supply to 110V )
These pre-drivers are the determining point of the life of your amp.
These may run hot , but will never burnt
( assuming there are no more faulty components starting from the input )
If it does then you may have to check the VAS circuits
and the long-tailed or differential input circuits.
If these works for a day , then connect your output transistors.
These are your pre-driver transistors ( left side of yellow line )
output transistors (right side of yellow line )
they should be replaced in pairs
Posted on Mar 04, 2011
dunnbiker
  • 8546 Answers
SOURCE: Sansui Amplifier RZ 7900 The surround
I can't find a manual but I'll take a stab.
When you say it fades are you being literal? In the digital world things usually change suddenly or stop altogether.
I'd look at the receiver for an indicator that indicates the multichannel nature of your incoming digital audio. Many have little maps or icons showing the number of speakers supported at any given time. That's a function of the incoming data stream and/or whatever the audio source it carries. For example, when loading a DVD I usually see 2.1 indicated on my unit while the low-tech menus and previews are active. Once the multichannel program commences the 5.1 indication lights up.
It almost sounds like the digital bitstream is being corrupted and the receiver shifts down to whatever it can manage to decode from it. Check the cabling that carries the audio. If it's optical instead of copper, I'd check to make sure there are no tight bends or kinks in it anywhere.
Posted on Dec 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Sansui 717
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 23, 2011
  • 49 Answers
SOURCE: how can i connect my pc to a sansui R-950AV receiver and then to speakers ?
Connect it to the (Auxillary) Jacks,
Posted on Dec 02, 2012
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
What type of connection wires do I need to connect a sansui au 9900a intergrated amplifier,and the tu9900 stereo turner to a kenwood multi cd player and a JVC td- w 5th double cassette.
You need cable called RCA. What goes out of one unit goes in to another. Get the owner manual and read it. It will show you how to connect the wires to the components.
Connect the RCA jack to to tuner input in back. CD player to the aux in back.
Try this:
http://stereobarn.com/how-to-connect-a-stereo-system1/
Sep 29, 2014 | Sansui Vintage Tu-9900 Legendary Amazing...
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
I have just reinstalled my Sansui component stereo system, and have a couple of problems. One is a scratchy noise on one speaker channel. The other is a seeming lack of results when I attempt to use the...
Buy some electronic contact cleaner, remove top, spray volume and balance pods and use the straw provided to target the small hole. Move controls back and forth as you apply the cleaner. If that fails! then the problem is a bad driver or audio output semiconductor.
Mar 16, 2012 | Audio Players & Recorders
Looking for an owner's manual for the Sansui Integrated Amplipier AU-D9.
Hi info851163...
Go to the following website and register to download your Owners/User Manual for your Sansui Intergrated Amplipier AU-D9.
Please take time to rate me thumbs up
http://www.hifiengine.com/manuals/sansui/au-d9.shtml
Also at this website...for $6.92 Canadian Dollar:
http://www.ioffer.com/i/Sansui-AU-D9-amplifier-Service-manual-79410631
Sep 15, 2011 | Audio Players & Recorders
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
Sansui QS-100 Problem with one rear channel
There are 2 250v 4a fuses inside the amp. They can blow and
that channel will cut out. Check the fuses.
Nov 19, 2009 | Audio Players & Recorders
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
Sansui Vintage Au-517 Intergrated Amplifier - Excellent Condition Logo
288 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
