I have split aircon model SAP K126GL..but lost the remote..if i buy the universal remote..where i can find the reset number?
Benimur
  • 6966 Answers
SOURCE: No sound
Hi, It seems that the SAP, no audio, distorted audio is a common problem for some RCA units even with the use of the original remote and in your case made more difficult with a replacement remote. Two things you can try: 1. Some say that unplugging the TV set for a long time, a couple of hours at least will do a hard/system reset on the microcontroller inside the TV hopefully resetting set-up the audio (including SAP) to default; 2. contact Customer Support at Thomson and explain your problem; 3. Try going a google on "RCA SAP manual reset"; or 4. Buy an original remote and not another replacement. Hope this work out for you and give you some ideas. Pls post again how things turn up. Good luck and kind regards.
Posted on Aug 06, 2007
coleslaw424
  • 43 Answers
SOURCE: turning the sap off using my universal remote
If there are any menu setting buttons on the t.v. itself then I would try using them to find the sap setting.
Posted on Jan 31, 2008
Marrie
  • 563 Answers
SOURCE: replace remote
Hi there
Most universal remotes work on this model.
Posted on Apr 02, 2008
SOURCE: TV in SAP mode and cannot remove. Lost original remote.
I had the same problem. You have to order a replacement remote with the MTS button (Multi Channel Sound)
Call RCA Support @ 1.800.338.0376 I believe the remote part number is RCR130TB1
Posted on Jan 08, 2009
  • 400 Answers
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Posted on Mar 19, 2009
I need a new remote control for a centrex air con machine model number CTAR35GW just wondering which one will work for this. I have lost the original!!!!!
http://www.remotecontrolwarehouse.com.au/index.php?route=product/category&path=177
The above link indicates is a remote appropriate for the air conditioner.
An alternative universal remote which might work is found at the following site: http://ultraplusremote.com/
Another universal remote for air conditioners is found at The Good Guys in Australia. http://www.thegoodguys.com.au/aircon-off-universal-airconditioning-smart-remote-airconoff
Whether or not any of these work with your unit is not something I can say with certainty. The first on the list does list your brand of air conditioner and is the least expensive of the lot. The last on the list is from a well know distributor. And the middle one offers a web video about programming the universal remote.
These universal remote search for codes much as universal remotes for TVs do.
Apr 07, 2015 | Heating & Cooling
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
Got mini split, lost, remote control, bought
Don't know a code for a universal remote, but you can order a new remote from an appliance parts supplier. If you have the model you posted under, the part number would be WJ26X10152 . (about $25) Make sure you have your exact model number from the model / serial number tag off the product to make sure you get the correct remote.
Jul 29, 2009 | GE AJCQ08ACB Air Conditioner
Dec 22, 2008 | RCA 257003 Remote Control
Turning the sap off using my universal remote
Jan 29, 2008 | Philips Magnavox 27MS343S 27" TV
No sound
Aug 06, 2007 | RCA TruFlat 27F520T 27" TV
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
