Question about Sharp AL 1631 Copier
Sharp al-1631 lines on copy only when original goes through docum
Only when the original goes through the automatic stream feeder tray only.It copies clean from the document glass. I've cleaned thetransfer charger several times, but it continues
Clean the narrow document scanner glass to the right of the main copy glass.
Posted on Mar 12, 2009
GETTING TWO STRAIGHT LINES ABOUT 2 INCHES IN ON BOTH SIDES FROM BORDER OF PAPER. ONLY HAPPENS WHEN FED FROM TOP OF AL-1631 COPIER. WHATS MY PROBLEM. THANKS BILL 520-294-2594 TUCSON AZ
Clean your scanner glass strip. Just lift up the automatic document feeder and look at the large glass. Next to it is a small strip of glass enclosed in a plastic frame. Clean this glass with a soft cloth and some glass cleaner. This will fix your streaks problem as this strip of glass is what is used when you make copies using the feeder. You can verify this by making a copy by laying your original on the large glass. This will probably come out clean with no lines. This will be your proof that the lines are coming from the strip glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Sharp AL 1631 Copier
Lined Copies
If the line is only when you feed the original from the top feeder (not when you place the paper on the glass)....clean the narrow glass (called the **** glass) under the feeder on the right hand side
If that is not it new drum and/or blade is called for
Oct 28, 2009 | Sharp AL 1631 Copier
Streaks on copies when using document feeder tray.
The little strip of glass on the right side needs to be cleaned, it has white out or some other type of foreign substance on it. you can use alcohol or windex to clean it.
Bob
May 06, 2009 | Sharp AL 1631 Copier
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
AL-1531 blank copies at 100%
I believe the document feeder is just hesitating some, try pushing the original as soon as it starts trying to feed. It won't fix it, but you'll know where your trouble is.
good luck
Bob
Apr 22, 2009 | Sharp AL 1631 Copier
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
Copies have black lines on them after i replaced the toner
does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Oct 30, 2008 | Sharp AL 1631 Copier
When put in feeder does not copy
lift feeder and look at the thin strip of glass, there will be a dot or something on it. Clean, as the paper is moving the dot looks loike a line to it,
Sep 12, 2008 | Sharp AL 1631 Copier
Paper size
Try setting the a4 original on the glass instead of the document feeder.  Load the a5 paper into the tray and try copying that way.
Sep 09, 2008 | Sharp AL 1631 Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
