Question about Imation Pivot USB 8GB Flash Drive 26658
Imation 8gb usb drive locked, how can i open it
It was locked
    New Friend:
    Problem Solver:
  • 7 Answers
Low level format the usb drive
Posted on Apr 20, 2013
Format imation defender F150
Connect it to your computer.
Open "My Computer".
Right-click on the icon for the device.
Click "Properties".
Click "Tools".
Click to 'format' it.
Jan 23, 2014 | Imation Defender F150 8GB USB 2.0 Flash...
I forget my password of imation defender 8go F150
The short answer is without the password, all info on the drive will stay encrypted and locked forever. It looks like you may still format it and at least get to reuse the drive. Formatting will erase EVERYTHING on the drive permanently. Here is some more specific information
http://www.secure-usb.co.uk/imation-faq
Dec 01, 2013 | Imation Defender F150 8GB USB 2.0 Flash...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
I have 8 GB pendrive, unfotunatly i delete the lock option, that time 8 gb reduce 2 gb, what i will do
you could try restoring it to its default
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
May 04, 2012 | Imation Products - imation - Clip Flash...
How can i remove usb ImationLOCK?
have you set a password on it
try the add remove program or uninstall a program
click start control panel uninstall program or it might have its own uninstaller
click start all programs look for imation lock
hope this helps
Nov 26, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have an 8gb imation that become 4mb free space why it happen?
click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your usb drive select format
(note formatting will remove all data on your drive)
then right click on your imation drive select properties you will seea mmount of space used and ammount of free space
hope this helps you
Nov 11, 2011 | Imation Products - imation - Clip Flash...
Imation 8GB pen drive problem. When I type in my
Check this: Right click - EXPLORE
Check if your USB drive has somekind of a button (sometimes looks like a tiny bar) it's a hardware lock
Jul 22, 2010 | Computers & Internet
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Imation Pivot USB 8GB Flash Drive 26658 Logo
50 people viewed this question
Top Imation Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Imation Office Equipment and Supply Expert? Answer questions, earn points and help others
