Question about Imation Pivot USB 8GB Flash Drive 26658
I am using imation 8gb usbdrive, recently it was locked stating that unlock it with apassword but i don't know how to open it
It was locked stating that it will open by using a pass word
    New Friend:
    Problem Solver:
  • 7 Answers
Pl use geek squad password remover
Posted on Apr 20, 2013
I have this flash dirve and somehow it's managed to lock I don't ever remember setting up a password and now I'm not able to open my document
Check the physical card. Some devices will have a physical lock switch, that or you encrypted the card. Does it ask for a password? If it does and you don't know it. I'm afraid your SOL. Format the card and move on.
Jan 24, 2013 | Imation Electronics - Others
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
To unlock nokia x6, 8gb mobile
Try code from service provider.or get code from Online site....
Sep 07, 2011 | Nokia X6 16GB Cell Phone
My usb locked with ImationLOCK v2 28 .exe, how to unlock ?
Proceed to the main screen of ImationLOCK (as per the picture below), click on where it's illustrated below as "log out".ralohcs.jpg
You will then be instructed to enter your password. Keep in mind that you have six attempts to input the correct password. If you do not input the correct password after the six attempts, the secure partition of the USB drive will reformat itself, destroying all of your files! You may click on 'password hint' for a hint to remind you of your password.
Jun 01, 2011 | Imation 4GB DEFENDER F100 FLASH DRIVE USB ...
I have an HP Photosmar R725, and I recently got an SD card for it. It says "CARD HAS WRONG FORMAT" and "Press OK to format card." When I do, it says it's locked. I have unlocked the...
The R725 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to use SD cards, 2GB and smaller.
May 24, 2011 | HP Photosmart R725 Digital Camera
Also have imation lock flash drive...i cant unlock or change my password...i dont know why, it says Drive is busy try again later...and it has not been working for days! what is the problem??? please help...
when its try later
scroll to bottom of screenright click in the bottom taskbar select task manager applications also processes see whats running if you see something running that should not be select end now
also download this freeware password utility
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Hope this helps you
Feb 02, 2011 | Imation Products - imation - Clip Flash...
Imation 8GB pen drive problem. When I type in my
Check this: Right click - EXPLORE
Check if your USB drive has somekind of a button (sometimes looks like a tiny bar) it's a hardware lock
Jul 22, 2010 | Computers & Internet
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Imation Pivot USB 8GB Flash Drive 26658 Logo
73 people viewed this question
Top Imation Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Imation Office Equipment and Supply Expert? Answer questions, earn points and help others
