Question about Philips 26pf5320 26-inch Flat Panel Widescreen Lcd Tv
Philips 26pf5320/79 faulty power supply
Hi there , i have a philips 26pf5320/79 (lc4.3a) lcd seams to have power supply fault , i have replaced 2 caps in the power supply but they looked ok anyway , fault is when powered up power led will go red-green-off red-green-off and so on , i think there is a fault in the standby supply but not shore , cannot fine anything by site . thanks .
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
  • 90 Answers
SOURCE: philips lcd 37pf9431d/37
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
Posted on Feb 23, 2009
  • 163 Answers
SOURCE: I have a Philips LCD
Service manual says: Error code 14 - audio power amplifier section. The tv switches to protect and blinks one long and four short flashes.
Posted on Mar 04, 2009
  • 53 Answers
SOURCE: phillips plasma wont turn on power light goes
power supply need replacement
Posted on Apr 04, 2009
  • 16 Answers
SOURCE: my Philips HTS3410D will not
Mine was exhibiting similar problems. It was the electrolytic capacitors in the power supply board.
There are 4 or 5 of them, and between 2001-2005 there was a bad batch of capacitors that came out of the far east, some of these capacitors were inferior quality so they dry out and fail. You can read about them on badcaps.net You can usually tell a failed electrolytic because the top cap puffs out slightly. Mine were actually almost pointy on top.
If you have the dexterity, soldering pencil and time, you can fix it yourself for about $5.00. Be warned that as soon as you open the case, you void the warranty, so if you don't feel comfortable, take it to a professional. Also, My remote is dying, so if someone wants to sell me their remote, let me know.
Posted on Aug 19, 2009
The tv will not turn on it starts blinking red lights, then when the power supply is removed in about five minutes. The power supply is plugged in and turns on. The model number is 42PF7321D/37
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I
Dec 20, 2010 | Philips 42PF9630A 42 in. Plasma Television
Tv will not come on use to be able to unplug it and it would come on but now we unplug it and when we plug it back up it tries to come on but goes back off
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
Dec 13, 2010 | SNK Magnavox 32MD357B_37 32 in. LCD...
Lines going through the display of my Philips LCD TV 42PFL5603D Philips 42", making the picture unwatchable, sound is not affected
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you.
2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. The entire board costs around $250 right nowbecause they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shutsoff on its own problem. I'mworking on uploading pictures to help guide people though the process aswell. Let me know if I can do anythingto help. Hope this helps and Good luck. Kaufman605
Dec 12, 2010 | Philips 42PFL5603D 42 in. LCD HDTV
Hi our LG plasma once it's turned off won't turn back on. the green light flashes and the screen is blank??
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
Kaufman605
Dec 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Turns on for 5 seconds then goes off, when unpluged and pluged back in power comes on right away then goes off again, also all power lights will flash
Kaufman605
Dec 12, 2010 | Hitachi 50C10 LCD TV
Hi, I have just bought Sony NX800. It does not work ?! As soon as I turn the power on, the name Sony appears on the LCD then turn off. There is a red light which is flickering (6 times) and get...
Kaufman605
Dec 12, 2010 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
50" Samsung tv (model #PN50B450B1DXZA) turns off
Kaufman605
Dec 12, 2010 | Samsung HP-R4262 42 in. Plasma Television
Tv has no video only audio
Kaufman605
Dec 12, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
My Astar 32" HDTV flat
Kaufman605
Dec 11, 2010 | Astar LTV-3201 32 in. LCD Television
My phillips lcd tv screen is totally black when I put it on ,
Kaufman605
Dec 11, 2010 | Philips 47PFL7403D 47 in. LCD TV
Philips 26pf5320 26-inch Flat Panel Widescreen Lcd Tv Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
