Question about Inverter 500 - 1000 Watt DC to AC - Safe for Electronics - Soft Start Techn
1500 w Compact, keep showing overload
Workng ok. left unused for 1week. But when swiched back on it went streat to overload but nothing! pluged in.
Overload indicator light stays red & continuous tone ups 1100
Take the battery out and see if it does the same thing when you turn it on.
Feb 06, 2013 | APC Back-UPS Pro 1100 (BP1100) UPS System
My friend has a gas heater and the pilot lite keeps cutting off on. He thought it was the heater and replaced it. The next day the pilot lite went out again. The heater downstairs stays on, hasn't went...
somethings wong with the venting ether he is getting a down draft ore it is pluged up take a lighter and see if the stack sucks the flame up if it does you dont have a problem but does not pull the flame up you have to take the venting aparte and find whats blocking your draft. the other thing your gas line might be pluged up.
Jan 20, 2011 | Williams 1403622 Gas Compact Heater
Frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
My xbox will turn on but nothing will show up, all the cords are in and it makes a weird humming noise when i turn it on then stops
get the yellow cord and the half red and half white in the back or side of the tv. behinde the xbox is a cord that's the color cords, at the of the cord that pluged in the xbox it says tv or hd, it swiches up or down see if that wroks if not you need to read the bood that came with the xbox.
Feb 10, 2010 | Microsoft Xbox 360 Console
Computer went off and starts anymore. unless wen I unplug a cable
Hi Leslie,
It could be your power supply is dead. The 4 cable wire is the 12v axillary power supply for the graphics. When unplugged you will get no graphics when plugged in nothing will work if that rail of the power supply is faulty. Hank
Feb 02, 2010 | Computers & Internet
HNSE05SS Compact Frig
There are very few parts on this unit. UNPLUG unit jump out the 2 wires to the t-stat. plug it in, if it runs the t-stat is bad.
After that theres the overload /start component on the side of the compressor. UNPLUG remove cover look for burnt wires , wires are ok feel if the compressor is HOT to the touch. if it is it could be off on internal overload. let it sit for a while plug in and listen for a hum or click in the compressor. If there is a Hum then click your back to eather your overload /starter is bad of the Compressor is bad. If you have an amp meter you can check the compressor by clipping the meter on power wire. on the information tag that has the model and serial # there is a amp draw for Lock rotor. If the unit draws Lock Rotor amps the compressor is bad.
May 21, 2008 | Haier HSB03 Compact Refrigerator
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Inverter 500 - 1000 Watt DC to AC  - Safe for Electronics - Soft Start Techn Logo
74 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
