Question about MSI KT3V (MS-6712-040) Motherboard
How to connect pin Jfp-1 Jfp-2
JFP 1-jfp2 pin contact
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Posted on Jan 26, 2008
  • 26 Answers
SOURCE: how to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Posted on Jun 08, 2010
What is the difference between JFP1 And JFP2
The mainboard provides one front panel connector for electrical connec-tion to the front panel switches and LEDs. Users can choose either the JFP1 or the JFP2 depending on their needs.The difference between JFP1 & JFP2 is that JFP2 is compliant with Intel PIn
Jun 04, 2014 | Computers & Internet
Power LED and other connection diagram for MSI 7142 motherboard
MSI Support > K8MM-V motherboard (ms-7142) > Main Support page,
http://www.msi.com/product/mb/K8MM-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Underneath the Download subheading click on the blue -
M7142v.1.0.zip (2005-09-07)
Click on the 'country' name nearest yours.
(U.S. is a country. Europe and Asia are continents)
A small window will come up -
Opening M7142v1.0.zip
Make SURE the small circle to the left of Save File, has a Green dot in it.
IF not; click in the small empty circle to the left of Save File.
Now go below in the small window, and click on - OK.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name. ( M7142v1.0.zip)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(Next to the red Adobe PDF icon)
There is the motherboard manual in PDF file form.
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
You can go page by page, to the page you want, using the Down Arrow; or if you know the page you want you can do this,
1) Put your mouse cursor in the page number box at top.
Left-click once. Anything in the page number box, is now highlighted in blue.
2) Type the page number.
3) Press the Enter key.
A) Go to Page 5 - Layout.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
On your motherboard there are two.
JFP1 and JFP2.
Junction Front Panel 1 and Junction Front Panel 2.
JFP1 is on the Right side of the motherboard, down in the Bottom/Right corner.
It sits Vertically on the motherboard.
Two columns of contact pins.
5 on the Left side, 4 on the Right side.
Go to Page 14 - Front Panel Connectors: JFP1/JFP2
The pins on the Left side are numbered ODD.
The pins on the Right side are numbered EVEN.
Starting on the Top/Left side, coming down;
Pins 1, 3, 5, 7 and 9.
Starting on the Top/Right side coming down;
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
This is reserved for the factory. Believe it is a 5 Volt (DC) test point.
D) Pins 2 and 4 are for the Power On LED light.
It is for a TWO wire Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
The JFP2 header is to the Left of JFP1.
It is situated Horizontally, and close to the bottom of the motherboard.
Two rows of pins.
3 pins on the Top row, 4 pins on the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the Right side, going towards the Left; Top row,
Pins 1, 3, and 5. There is NO Pin 7.
Starting on the Right side, going towards the Left; Bottom row,
A) Pins 1, 3, and 5 are for a THREE wire Power On LED light.
I assume Pin 1 is for the Negative wire ( - ), and Pins 2 and 3 are for the two Positive wires.
It's for a dual color Power On LED light.
Example: Turbo Mode has a Green light, Normal Mode has a Yellow light.
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Internal speaker is used to hear the BIOS Beep Codes.
For additional questions please post in a Comment.
[Thought you may want the motherboard manual, too]
Regards,
joecoolvette
Mar 04, 2013 | MSI K8MM-V Motherboard
How to connect switch on/off from board to case
http://www.ebay.com/itm/MSI-K8MM-V-MOTHERBOARD-AMD-SKT-754-MS-7142-TESTED-WORKING-/271103601623?pt=Motherboards&hash=item3f1f08abd7
Put your mouse cursor in the middle of the photo. Now move it around. Any bigger than that, and you need a microscope.
Bottom RIGHT corner. See where it states JFP1? From it go UP the motherboard. There is a mounting hole, then the Front Panel header.
JFP1
It has Black, and Red, and Yellow, and Green, and Blue in it, below it's contact pins.
MicroStar International Support > MSI K8MM-V motherboard > Support Main page,
Hover your mouse on Download.
(Overview / Specification / Download / Support / etc)
Under the Download subheading click on the blue - M7142v1.0.zip
Click on either Download 1, Download 2, or Download 3.
(Or click on the country name nearest yours. I have never seen Download 1, 2, and 3 before)
A small window will come up on the right -
Make SURE there is a Green dot, in the small circle to the left of Save File.
If there isn't; left-click in the empty circle to the left of Save File.
Now go to the bottom of the small window, and click on OK.
A small window will come up on the left.
Another small window will come up.
Go to the far left of this window, and click on - Extract all files
Now DOUBLE-click on the file name - M7142v1.0,
next to the red Adobe PDF icon.
There is your motherboard manual.
The PDF file page, and the actual manual's page, are not the same number of page.
Go to Page 5 - Adobe Reader page number, or Page 1 - Actual manual page number.
Be sure to note JFP1 and JFP2.
(Junction Front Panel 1 and Junction Front Panel 2)
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is JFP1.
JFP2 is an auxiliary front panel header. Explanation follows.
JFP1 is two columns of pins.
5 on the Left side; 4 on the Right side.
Pins on the Left side are numbered ODD.
Pins on the Right side are numbered EVEN.
Starting at the Top, coming down on the Left side;
Pins 1, 3, 5, 7, and 9.
Starting at the Top, coming down on the Right side;
There is NO pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light. Usually Red)
C) Pin 9 is N/C.
Not connected.
Probably 5 Volts used by the factory for testing the motherboard.
D) Pins 2 and 4 are for the Power ON LED. (Light)
F) There is NO pin 10.
JFP2 is to the Left of JFP1.
Two rows of pins.
3 pins on the Top row; 4 pins on the Bottom row.
The 4 pins on the Bottom row are for a speaker.
For an internal speaker so you can hear BIOS Beep Codes.
Pin 2 is all the way to the Right; Pin 8 all the way to the Left.
(2, 4, 6, and 8)
Believe Pin 2 is for the Positive ( + ) wire. Pin 8 the Negative ( - ) wire.
The 3 pins on top are for a Power On LED light, that has 3 wires.
A dual color LED. (Yellow/Green? Normal/Turbo)
Regards,
joecoolvette
Nov 17, 2012 | MSI K8MM-V Motherboard
K9n6pgm2-v pin out
MSI Support > K9N6PGM2-V motherboard > Main Support page,
http://www.msi.com/product/mb/K9N6PGM2-V.html
Now click on the blue -> M7309V1.2.zip
Click on the country name nearest yours.
Opening M7309v1.2.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If not left-click once in the small empty circle, to the left of Save File
Now go below in the window, and click on OK.
A small window will come up on the left. Allow the file to download all the way.
Now DOUBLE-click right on the file name.
In the next small window go to the left side, and click on -
Extract all files
At the bottom of the next three small windows, left-click on
In the last small window go to the file name next to the red Adobe PDF icon, and DOUBLE-click on it.
7309v1.2(G52-73091X3)
There is your motherboard manual in PDF file form.
( Plus + icon increases the view size when you click on it.
Minus - icon decreases the view size.
When I refer to a page number it will be for the PDF reader, and not the actual manual's page )
Go to Page 8.
Motherboard Layout
JFP1 is the Front Panel header.
JFP2 is an additional header. To be discussed after JFP1.
JFP1 is on the Right/Bottom corner. It is placed Vertically.
(Parallel to the right bottom edge of the motherboard)
Above it's left corner is JUSB2. (Front Panel USB header 2)
Above JUSB2 is the SATA2 connector. To the left of the SATA2 connector is the SATA1 connector.
To the left of the SATA1 connector is the CMOS battery.
The contact pins are arranged in two columns.
4 pins on the Left side, 5 pins on the Right side.
Go to Page 14. JFP1 pinout, and JFP2 pinout, is at the Bottom of the page.
JFP1:
Starting on the Bottom going towards the Top, Right side;
Starting at the Bottom going towards the Top, Left side'
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
IF the HDD LED is dim when the harddrive is active, switch the wires around.
C) Pin 9 is N/C. Not Connected. (Probably 5 Volts positive, and used by the factory only)
D) Pins 2 and 4 are for the Power On LED. (Light)
IF the PWR ON LED is dim when the computer is on, switch the wires around.
JFP2:
Below JFP1 is a header that is placed Horizontally. It is parallel to the Bottom edge of the motherboard. This header with 13 pins in it, is the JLPC1 header.
(Starting on left side at the Top row; 4 pins, no pin, 2 pins.
Starting on the left side at the Bottom row; 7 pins)
To the left of the JLPC1 header is the JFP2 header.
4 pins across the Top row, 3 pins across the Bottom row.
The top 4 pins across the top are for an internal speaker. Used to hear BIOS Beep Codes.
Starting on the Left side coming towards the Right, top row;
No indication of polarity.
Believe pin 2 is for the Positive wire, and pin 8 is for the Negative wire.
Starting on the Left side coming towards the Right, Bottom row:
Pins 1, 3, and 5.
These pins are ONLY used for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED.
(One example; Green Turbo, Yellow normal)
The rest of the pinouts are listed in the manual.
Have additional questions? Post in a Comment.
I also downloaded the manual.
Regards,
joecoolvette
Oct 16, 2012 | MSI K9N6PGM2-V Motherboard
MSI 760gm-p21(fx) MB, JFP1 AND JFP2 PINOUTS I NEED TO SEE A DIAGRAM SHOWING ME EXACTLY WHERE TO PLUG the cables on the MB
http://www.msi.com/product/mb/760GM-P21--FX-.html
(Overview/ Specification/ Download/ Support/ Where to Buy)
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side coming across to the Right, Bottom row;
If the HDD LED is dim when the Harddrive is active, switch the wires around.
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
If the PWR ON LED is dim when the computer is on, switch the wires around.
JFP2:
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 1 is for the Negative ( - ) wire.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
Regards,
joecoolvette
Jul 28, 2012 | MSI Computers & Internet
Front panel configuration
Motherboard installed in computer case;
Processor to the Top, 3 Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
Down in the Bottom/Right corner, is JFP1, and JFP2.
The Front Panel header is JFP1. (Junction Front Panel 1)
The header with two rows of pins, and is positioned Horizontal. It is parallel to the bottom of the motherboard.
(The other Front Panel header is JFP2. It is positioned Vertical, and is above JFP1. You may be using it also. Read on)
There are two rows of pins for JFP1.
5 across the Top, 4 across the Bottom.
The pins on the Top row are numbered ODD.
The pins on the Bottom row are numbered EVEN.
Top row, starting from the Right side, going towards the Left;
Bottom row, starting from the Right side, going towards the Left;
If the Harddrive activity LED light is dim, when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is/was for the factory.
D) Pins 2 and 4 are for the Power On LED light. A Power On LED light that has 2 wires.
If the Power On LED is dim when the computer is on, switch the wires around.
Looking at JFP2. (Junction Front Panel 2)
Vertical with two columns of pins.
3 on the Right side, 4 on the Left side.
The Right side is numbered EVEN.
The Left side is numbered ODD.
Starting at the Bottom on the Right side, going Up;
Pins 1, 3, and 5.
Starting at the Bottom on the Left side, going Up:
A) Pins 1, 3, and 5, are for a Power On LED light, that has 3 wires.
Pin 1 is for the Positive wire. (Dual color LED )
B) Pins 2, 4, 6, and 8 are for a Speaker. The speaker for BIOS Beep Codes.
Pin 8 is for the Negative ( - ) wire.
Regards,
joecoolvette
Jun 24, 2012 | MSI MS-6580 Motherboard
How to connect jfp 1
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
Emachine W3410,the main three wire from the motherboard to the power botton on and off switch was remove and iam not sure wish pin they go to .power led, power sw, H.D.D.led,
The eMachines W3410 uses an MSI ms-7145 motherboard.
Also known as RS480M
This is MSI Support, and the download page for the motherboard manual, for the RS480M motherboard,
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=204
To the Right of the photo of the motherboard, you will see a gray bar with, BIOS, Driver, Utility, Manual, and RSS.
Left-click on Manual.
On the next page look under the heading to the right - Document.
Left-click on the blue - E7145v2.1.zip
On the final page click on the country nearest yours.
A small window will come up with the heading -
Opening E7145v2.1.zip
Be sure that Save File has a green dot, in the empty circle to the left.
[If not, Left-click on the empty circle to the left of Save File]
Now click on OK, below.
Where this file will go.
If you Do Not, have your documents set to save to your My Documents folder (Documents for Vista), the file will go to your desktop screen.
In either place Double-click on the file. Now go up to the left, and click on - Extract All Files.
Click on Next, and Finish.
You will now see a PDF icon. Double-click on this icon.
Go to Page 15.
The plastic panel on the front of your computer is the Front Panel.
This is where the Power On switch, Power On LED, and HDD LED are located.
The connector on the motherboard where the cables (Wires) attach to, is the Front Panel header.
The front panel header is a series of pins, sticking up out of the motherboard.
The MSI ms-7145 motherboard, (RS480M) has the Front Panel header separated into two headers.
JFP1, and JFP2
Looking at the motherboard with the Processor socket to the top, and the Ram Memory slots to the right, the JFP1, and JFP2 front panel headers are located at the extreme bottom Right, of the motherboard.
[Use the Zoom In feature (+ at top of file) to enlarge the motherboard layout on Page 15]
Now go to Page 38.
Page 38 shows the connections for the JFP1, and JFP2 headers.
The JFP1 header, and the JFP2 header, consists of two rows of pins in a horizontal column.
The pins are arranged parallel, to the bottom edge of the motherboard.
Right above the JFP1, and JFP2 header may be three pins, with two of the pins have a jumper. We will not concern ourselves with this jumper header (BIOS with Protect Jumper)
The JFP1, and JFP2 headers are close together. There is no separation in-between them.
The JFP2 header is for an internal speaker.
The JFP1 header is for the Front Panel cables.
The JFP1 header pins start from the right side of the motherboard, and go towards the left.
There are 5 pins across the Bottom. (Going from right to left)
There is NO pin, then there are 4 pins across the Top.
(Again, going from Right towards the left)
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting on the Right side, going towards the left for the Top row of pins, the pins are numbered,
10 (NO pin for 10), 8, 6, 4, and 2.
Starting on the Right side, going towards the left for the Bottom row of pins, the pins are numbered,
9, 7, 5, 3, and 1.
1) Pins 2 and 4 are for the Power On LED.
2) Pins 6 and 8 are for the Power On switch
3) Pins 1 and 3 are for the HarDDrive activity LED
4) Pins 5 and 7 are used for a Reset switch. (If applicable)
5) Pin 9 is not used.
Apr 30, 2010 | E-Machines T3958 (827103050974) PC Desktop
How to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
Sep 23, 2009 | MSI P4MAM-V SND/LAN/VIDEO (6787060)...
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
MSI KT3V (MS-6712-040) Motherboard Logo
42 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
