Question about MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55)
CONNECTING SEQUENCE OF PLUGS ON USB 1 AND USB 2 TO MOTHER BOARD
  • MSI Master
  • 3,606 Answers
Hello you can download the manual here at MSI:
http://www.msi.com/product/mb/KM4M-V.html#/?div=Manual
You will need adobe reader, to read the content.
The manual should show you how to connect the cables to the mainboard.
If other files needed select in the download option.
Good luck
Posted on Apr 21, 2013
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Mar 24, 2010 | Antec Computers & Internet
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
CAN'T IDENTIFY MY MOTHER BOARD
Download CPUZ from this link. This app will give your mobo info.
Apr 02, 2009 | Computers & Internet
JP3 USB header
Dear friend here your solution
all usb jumper setting on mother board
http://www.geocities.com/jisfy/USB.JPG
If it helpfull please rate me. thanks sumon (jisfy@yahoo.com)
Mar 24, 2009 | Abit TH7-RAID Motherboard
Windows does not start when I leave my printer plugged in
First if your USB cord is too long try to switch it out with a smaller cord. If that does not work please unplug printer boot up and enter the BIOS settings.
http://www.michaelstevenstech.com/bios_manufacturer.htm
Then check to make sure your boot sequence is setup to Hard Disk first and not USB, you need to make sure the USB Boot Device does not have priority over HDD.
Finally make sure that USB Emulation is not turned on in the BIOS.
If all of the above does not fix the issue you may have a faulty USB port or a bad mother board.
Jan 17, 2009 | Lexmark P4350 All-In-One InkJet Printer
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
Wirring for my mother board
The board may have tiny words printed on it telling you what the plugs are.
Most newer boards are fool proof in that only the specified cables can be plugged in. generally the Hard drive plugs into IDE 1 or MAIN and CD drives plug into IDE 2
Video cards go into the First slot usually. It may be AGP or PCI or PCI express depending on the board. The extra PCI slots are for extra devices like NIC cards and Sound card. Power cables cant be plugged in wrong because there male to female and only fit into there designed plugs.
Make sure the motherboard is installed correctly and is not touching the actaul case but held up with spacers. you can find these at most Computer stores.
Really try and find the manual online if you can. It may be necesary when plugging in the little pins for the power switch and USB pins.
good luck.
Jun 12, 2008 | Lenovo Computers & Internet
MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55) Logo
89 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
