Question about Arris SURFboard SB5120 Modem
Connect Modem to Laptop
Is it possible to connect the modem to my laptop using usb cable
  • 41 Answers
Yes. you plug it in. you plug your cable or DSL line in. Then if they have provided you with a USB A-B (like a printer cable) then you go from the back of the modem to the USB port of your laptop.
Posted on Mar 11, 2009
Can I use USB Cable direct to laptop from modem? Ethernet cable from modem is connected to router which is connected to desk top PC. OR should I connect a ethernet cable from router to laptop? Type of...
Hi Friend, It depends that whether your router is wireless or wired. If it is a wireless router then there is no need to connect the laptop with the cable, you can use the laptop wirelessly If it is a wired router and as you said that the Desktop is already connected to the router with the cable so in that case you have to get another ethernet cable and can connect it from the router to your laptop
Dec 08, 2010 | Computers & Internet
Acer5536 laptop will not connect to the internet wireless will connect by ethernet cable why
you might have a modem with an ethernet connection to connect to the net .
if you have a laptop you can choose a wireless usb broadband modem which can work on a desktop also once you recieve the modem just insert the modem into a usb port and follow the prompts you might need some drivers for the usb broadband modem which can be supplied by the ISP internet provider
hope this helps
Nov 14, 2010 | Acer 91.AB370.001 Network Adapter
How can i connect my laptop bought 2 weeks ago to my cable modem its a sb5101 cable modem by motorola
This modem is USB or Ethernet. I strongly reccomend using the ethernet and not the USB option as USB will lose some speed.
An ethernet cable is a standard RJ45 Jack'd cable (both ends) - check google images if unsure but you'll see the plug in the modem that is the same as one on your laptop.
If you dont have an ethernet port on your laptop (possible but unlikely) then you'll have to use the USB option - this is a usb cable similar to a printer usb cable (square usb end at the modem and flat usb to the laptop)
Hope this helps! please dont forget to rate :)
Nov 03, 2010 | Arris SURFboard® SB5101 Cable Modem
Bought a new laptop; want to connect it to this modem via wireless
is your pcx1100u cable modem is not wireless ready? only router have a wireless lan... buy it...
Jun 16, 2009 | Toshiba PCX1100U High Speed Cable Modem
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
Not recognize my pc but not laptop
I have yet to see a single DSL modem that will allow USB and Ethernet connections simultaneously (and actually work properly). You should install a DSL router instead.
May 08, 2009 | AT&T High Speed DSL Modem
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
It sounds like you are setting up your new laptop to connect to your cable modem. If that is correct, your laptop should only have one ethernet port. The other port should be for the modem, but it does look very similar to the ethernet port. I would highly suggest getting an inexpensive router to place between your laptop and your cable modem. The routers come with detailed instructions on how to connect it to the cable modem and the computer. This will provide 2 things for you. The first is ease of connection, and the second is protection from all of the bad stuff on the Internet.
Mar 26, 2009 | Sony Computers & Internet
Laptop doesnt find connection to cable modem
download setup wizard to find connection from windows
Feb 12, 2009 | Acer Aspire One PC Notebook
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Arris SURFboard SB5120 Modem Logo
152 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
