Question about Archos 35 Home Connect 4GB
I've just got an Archos 35 Home Connect 4GB, but tapping on the heart icon to save favourite radio stations doesn't work, does anybody have a solution?
When I tap on the heart icon a box opens which gives the name of the radio station and says add to favourites. I've tried tapping on this box and not tapping on this box, but in both cases nothing happens and the radio station is not saved. I sent an email to Archos and they told me to reset android, but that didn't work and since then Archos hasn't answered emails.I get the impression their after sales technical service is useless.
SOURCE: Archos not coming on
This happens to me alot. You need to take out the battery then push the reset button on the right hand side of the battery connector on the system.
Alternatively, take out the battery and leave it out for about 6 hrs. when you put the battery back in, it would work.
It took me several weeks to solve this problem when i first bought it
Posted on Dec 03, 2007
SOURCE: Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Posted on Dec 13, 2007
  • 8 Answers
SOURCE: Transfer file to Archos 5 using usb port on DVR Station Dock
On your Archos 5 go into tools -> Files and you should have two Archos 5 tabs. Change one to your USB stick and the other to the Archos 5 and copy and paste. I have not tested this, but this should work.  Good Luck.
Posted on Feb 02, 2009
SOURCE: connect connect my archos 605 with WEP address!!!
i have a 20 to 30 digit wep key and i just changed the settings to 128 bit and made it a hexadecimal wep. (hexa- ?) it should work.
Posted on May 27, 2009
SOURCE: recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Posted on Feb 26, 2011
Archos tv+ doesn't boot, contantly(steadily) blinking. Can anybody help?
Hi, I had the same problem, no booting but only blinking red LEDs. I noticed the harddisk wasn't making any sound that it was working. I changed the original power supply adaptor (12v) with one producing 15v output voltage. And it's working again.
Dec 25, 2012 | Archos TV Plus, 80GB 80 GB Hard Drive
WMA stream on a constant loop for my favourite radio station
Since other stations worked perfectly, perhaps the other station was streaming a loop.
Otherwise try this: Support Cobra Electronics Corporation
Mar 21, 2017 | Cobra Radio Communications
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
I have the Archos 101 internet tablet but have been having trouble connecting to the wifi recently, I try to connect to a secure connection (I have the password and it is correct as I did connect a few...
Hi there. I noticed that sometimes Android devices seem to have trouble connecting to certain access points or.they seem to stop connecting alltoghether to certain routers. Sometimes this method can help: Select the network you are trying to connect to and select "forget this network". Reboot the tablet and try to reconnect again. Sometimes this doesn't work on the first try. If that doesn't work I have heard of other fixes but they require "rooting" the tablet which could be potentiall dangerous. Another thing you can try if that doesn't work is change the security to a different encryption type. Your password will either be WEP or WPA. Whatever it is try to change it to the other. I cannot give you detailed instructions on this because I don't know your router model or its current settings. Hopefully this helps and leave a comment if you have further questions. Good luck!
Sep 09, 2011 | Archos 101 Tablet PC
Cannot get google account on my defy says cant find reliable connection to server. what can i do to make it work. and it says that: "this could be a temporary problem or your phone may not be...
If you haven't configured your phone to access the internet yet, and you want to do it through your network carrier's data plan, bear in mind their APN settings. Contact they, in case you don't know such data. Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in a 'Name' for it, and, at least, your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, prior you started making these changes.
On the other hand, if you want to access the internet through wifi (e.g. your home's wireless network, or an internet cafe), go to 'Menu > Settings > Wireless & networks' and tick the 'Wi-Fi' checkbox, in order to turn your phone's wifi radio on. Then, tap 'Wi-Fi settings', and, if the network you want to connect your phone to doesn't appear on the available networks list (e.g. a hidden network), tap 'Add Wi-Fi' network' and fill in 'Network SSID', select the security method, and fill in the password, if needed. When you finish, tap 'Save'. You can also specify how your phone will use its wifi radio. Tap 'Menu > Advanced > 'Wi-Fi sleep policy'. Again, press the back button as many times as required to return to the home screen.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Apr 28, 2011 | Motorola Mobility Defy Cell Phone
I have purchased this product with a software package that includes Kindle whispersync. I can not download any books that I purchased. it states Invalid Item, Please remove from your device and go to...
I've had the same problem and was told by an Amazon customer service person that the Archos 7 Home Tablet must not be a recognized device. I've brought the issue to the attention of Archos technical support and they claim to know nothing about another companies software and could not help. I don't think there is a solution, I think it just doesn't work on this device. I don't know why they included the kindle e reader app if it is useless on this device. I also rec'd Syncables 360 software and I can't get it to work either and technical support for that software is non existent. I tried calling the phone number a couple of times and was disconnected each time. I will be contacting the company I purchased this from to log a complaint.
Apr 15, 2011 | Archos 7 HOME TABLET V2 8 GB Hard Drive
Where can i buy a docking station for my archos 43vision
Here is variety of docking station and universal mouting for your Andriod Palm tablet PC Notebook,
Feb 05, 2011 | Archos 28 Internet Tablet
Archos hard drive
The repair function only works on the internal hard drive and there is no other need to use it...external hard drives generally only connect through the archos dvr station which is sold seperately. You can buy one at archos website or circuit city among others...I've been told that it can be done without the dvr station but have found nothing in the archos docs to support this thus far nor have I ever seen it successfully done, in person, without the dvr station.
Oct 01, 2008 | Archos 605 WiFi Digital Media Player
Archos 35 Home Connect 4GB Logo
42 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
