Monitor will not display and stay on
My green power light comes on but my monitor will not display. If i push the menu or auto button it comes on and displays and then come back out. I am using my old monitor to write this and work on the web Thank you for your help Jim
  • chrisbud32 Apr 22, 2009
    monitor powers up shows the screen very briefly then goes black
    monitor powers up screen shows then goes black in about 1 second
  • 94 Answers
Try to switch to the other monitor so that you can identify the problem if monitor or your system unit
Posted on Mar 12, 2009
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
I have a Dell e173pfb monitor. i push the power button and green light comes on screen comes on for a second with no problem then the backlight goes off. I can still see an image with a flashlight though....
You need a new backlight inverter board. If you dissasemble the monitor you will see a circuit board with 4 2-wire connectors connected to it. This is the board you need to replace. Typically they run from $15 to $40. Usually just easier to replace the monitor. Another idea is to reduce brightness levels on the monitor in the menu while looking at it with your flashlight. Then power off then power on the monitor and it might stay on longer.
Aug 16, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My monitor will go on but it will not stay on
Either sleep timer is on or the refresh rate is set higher then the screen to handle or scheme is not set for laptop.
you can right click on main screen to access display and advanced options.
Oct 23, 2009 | Acer AL1715 17" LCD Monitor
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Vusys hd19a monitor is always on standby
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Dec 11, 2008 | Microsoft Likom HD19A 19" LCD Monitor
Colour changing
I found this on another site:
[QUOTE=numbnutjas]I had the same problem along with lots of others who bought this great prolite monitor.
Whenever you turn the power off for more than five seconds the monitor looses an important bit of info of a hidden menu. Iilyama are not keen on publicizing the fact their monitor has a bug!
Follow these steps very carefully, it might not work the first time but it does work I promise.
Make sure that the moniter power button is off.
Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.)
plug monitor back in mains.
hold down + and - on the monitor
now hold down power button on monitor
let go of power when power button when the green led lights up
let go of + and - buttons
wait a few seconds and press menu, a hidden menu will appear in the top right
use the + and - buttons to move the hilighted option over the auto colour option in the menu
push the menu button.
It does work, but if you have any problems: email at : miamoo2038 at hotmail dot co dot uk
Feb 23, 2008 | iiyama ProLite E434S 17" LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Blank Screen
Can you see anything at on but dimly? If so thats is the backlight tube If you cannot see anything then it is a major fault eitherway a repair shop job I should think
May 30, 2007 | HP L1902 19" LCD Monitor
Computers & Internet Logo
225 people viewed this question
David Payne
David Payne
