Question about Vtech Whiz Kid Learning System by
Old whiz kid 1984
Is there anywhere I can send this to get fixed. The ribbon from the key board to the computer is broken. There could be something else wrong with it. I'm not sure.
Whirlpool oven model rbd306pdb15 has f5 error code and lights are on. Will not heat. Changed door latch, no help.
if you changed the latch the only other things are a broken wire or a bad computer board,this machine has two boards the clock assy. part WPW10438751 and another board part WP8301848.if you go to repair clinic you can order both boards install them first wp8301848 and see if it works because this is the cheaper of the two boards but you can send back the board you don't need up to 365 days,unfortunately when the machine has more than one board it's hard to say what one is bad,i have removed the ribbons on some units and when you plug the ribbon back in it works,possible dirt in the connection or something like that,sometimes when you remove the board you can see a burn mark on it or it smells cooked,wish i could give you a better answer but f5 is a bad latch,broken wire or computer board,can you let me know what you find thanks so other people might be helped by what you find,and i'm sure you know to kill the power to the unit before you work on it always do this.
Nov 08, 2017 | Whirlpool Ovens
I have forgotten my password
Hello, Angie. You can find your Driver Whiz product key by downloading and installing Belarc Advisor: Belarc Advisor Free Personal PC Audit Version 8 4 This program will tell you absolutely everything about your system, including program serials for your installed programs. Let me know if you need any more help.
Marc
Sep 21, 2014 | Driver Whiz
Alcatel
Sorry for negative response. Normally speaking you cannot retrieve anything once it has been erased. The traditional "Waste Basket" is not accessable. But if you can find a twelve year old whiz kid - who knows?
Apr 30, 2014 | Cell Phones
Users Manual
Go to www.vtechkids.com. Under customer support, you will see a link there where you can download pdf versions of Manuals for different vtech toys. If you can't find it there, then you need to call VTECH. Contact info can also be found on their website.
Feb 14, 2014 | Vtech Whiz Kid Learning System by
Driver Whiz Code
You should contact the software manufactures or distributors customer support and they will assist you, otherwise the keys are normally provided with the paperwork for the software when you purchased it.
Apr 11, 2013 | Driver Whiz
I need registration keys for driver whiz
Why driver whiz?! driverupdate us is x10 times better. Check it
Mar 06, 2013 | Driver Whiz
Sharp aquos will not turn on. power opc light flashing
I got a Sharp Aquos Quattron LC-60LE847U, a 60inch LED TV, I only brought it for a year and 4 months, factory only a have one year warranty. Last week when my kid try to turn on the TV, the TV power light keep repeat blinking in 2 slow and 5 fast sequence, don't know what did it mean. When I press the power button, the light will stay on for few seconds and it kept blinking after, the TV cannot turn on at all.
My kid have called the Sharp help line in US, number found in user manual, but the Canada help line are different number, it is 1-877-278-6709, they told my kid to unplug the TV, hold down the Input and the Volume down key, then plug the power back on, the TV can turn into service mode, it have a K icon on the screen, but every time I selected the menu, it went away very quick. Then the customer assistant told my kid to call service.
When I did a lot of research, every solution seems to point to the power supply, so I bought a power supply from ebay, replaced it, it does the same thing, no different at all, then I turn the TV back on in service mode, to try to do a reset from the menu, upgrade the firmware, re-seat all ribbon cables of the main board and the middle logic board (Not sure what is that board call, it is in the middle of the TV), neither way can make any different, the TV light still blinking in same sequence.
So I kept doing the research, I find out another way to reset the TV back to factory setting just by holding down the Volume up and Channel down, then plug in the TV, kept hold it down those 2 buttons until the TV came back on. TV will reset for just by doing this. Happy news, problem seems to get fixed, but not 100 %. The TV seems no problem to turn off and on after reset, but if I unplugged it, the blinking problem will come back, but if I reset it one more time, it will works again until I unplug it again. It is better than completely dead.
Then I unplug the TV, removed all ribbon cables (6 ribbon connectors), use sand paper to clean all the ribbon cable contacts, don't rub it too hard in case the cable contacts get destroy, then re-seat all the ribbon cables. After I did that, everything back to normal and my TV got fixed completely.
This seems to be my way to fix it, not sure everyone can use the same method to fix their blinking power light problem, but I hope this tips can help some people to save big buck to the Sharp service. This TV is over $2000 dollars and I brought few pair of the expensive 3D glasses, I do hope it can last longer, didn't expect it have problem already, it just less than a year and half old and even I bought the power supply to tried to fix it but I ended up didn't needed to spend any money and solved the problem.
Hope this helps.
Aug 22, 2012 | Sharp AQUOS LC60LE847U 60 inch 1080p...
Driver whiz registration
I'm sorry but this is not a warez site...We can't give out activation keys or access codes.
Jul 29, 2012 | Driver Whiz
Dvd player, pvd-709
Hi lindy,
My kid broke the ribbon tape, so I took it apart. It is easy to fix all you have to do is plug it back in if the connectors are in tact. 1 goes to the reader and the other plugs into the circuit board. My problem is that I cant find a new flat ribbon cable/wire anywhere.
Aug 12, 2008 | Durabrand PDV-709
Vtech Whiz Kid Learning System by Logo
87 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
