Evantair heater manual - Heating & Cooling
Do you look after replacement parts for Evantair ceiling fan 3-blade ? I need a new light cover ?
Julie,
Fixya does not sell parts. Try a general Google search using your manufacturer and model number.
Best regards,
Feb 25, 2018 | Dryers
Evantair manual 2000D
I am happy you have one but without telling us what your problem is we cannot help you.
Feb 05, 2014 | Dehumidifiers
Evantair water tray
you have problem with the evacuate sistem pipe condensing
Jan 04, 2014 | Heating & Cooling
Broken power switch on evantair oil heater
An Oil heater is not a two way radio...
Peter
Nov 06, 2012 | Heating & Cooling
Is there a customers service number i can call for my reddy heater problems
I would call Beals & Bobs @ 712-225-6173 or you can go to www.bealsmotor.com and email them and they will answer you questions and email an owners manual if you want. They have a service manual for these heaters at http://www.bealsmotor.com/heater.html and then click on the Desa manual that you need. The kerosene manual if for heaters with a spark plug and the Hot surface manual is for heaters with an ignitor.
Jan 14, 2012 | Reddy Heater-170,000 BTU Kerosene Deluxe
Need a manual for a maytag electric water heater. model # HE2950S
More information is needed about this heater.
The label located on side of tank should show manufacturer.
Maytag does not manufacture water heaters.
Maytag is a brand name used to market water heaters made by other companies.
Maytag offers a phone number for water heaters:1-866-362-9898
Other resources:
-If the water heater has electronic control box on top, then following American Water Heater Company manual might be suitable:
http://www.americanwaterheater.com/support/manuals/energysmart.pdf
-Electric water heater instruction manuals can be found on following link:
Each is basically the same, unless there is electronic control box.
http://www.americanwaterheater.com/support/manuals.aspx
-If you have ordinary two-element 240volt water heater and are having problems, or want information on maintaining water heater, then following link is useful:
http://waterheatertimer.org/DIY.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#cleanelectric
Sep 28, 2011 | RELIANCE ELECTRIC WATER HEATER
Need to know how to replace the wick
The first thing you need to determine is the correct model number of your heater. Once you've done that, go to the GHP Group Inc, website listing the heater manuals and locate the appropriate manual for your heater model and click on the link for your heater.
After you've selected the appropriate manual, you can either download it to your computer or print it out. Inside the manual you'll find the instructions on how to replace the wick. The kerosene heater manual I reviewed listed an incorrect phone number to call to order a replacement wick. I suggest you use the new GHP Group's number to order your replacement wick: (877) 447-4768.
If you have a different Dyna-Glo heater than a kerosene one, you should still be able to locate the appropriate manual on the GHP Group's heater website.
Hopefully, you'll have your heater up and working again in no time.
Jan 12, 2011 | Dyna-Glo (PPH16-LP) Utility Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
