Question about Dryers
Fridgemaster electrical diagram for model bf 315
I need a diagram of the wiring from the plug to motor and inside temp contoller
SOURCE: jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Posted on Jul 07, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
SOURCE: Suzuki wiring diagram
http://www.suzuki-club.ru/forum/downloads.php?do=cat&id=5
Posted on Jun 01, 2009
  • 142 Answers
SOURCE: Kenmore dryer model 110.62066102 electrical wiring diagram
contact manufacture.
Posted on Sep 14, 2009
Wanting to locate temp sensor sender on 1992 Holden Rodeo Isuzu motor
There's this website www.reliable-store.com
They have books on ALL vehicles.
it covers wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, troubleshooting owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
Mar 16, 2018 | Isuzu Cars & Trucks
WILL AN AU FALCON STARTER FIT A BF 2006 MODEL
You should go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Mar 14, 2018 | Cars & Trucks
04 iMpala LS blowr motor stopped! here are the stats: *right dash fuse was ok *big 30amp fuse was ok *new blower resistor *multifunction switch working fine *low miles on car.
Finding a wiring diagram an using a DVOM - digital volt ohm meter an testing the electrical circuit is the proper way to diagnose electrical problems . Looking at the wiring diagram for your vehicle i see it doesn't have a blower motor resistor , it is a blower motor contol processor . Electronically controlled .
HVAC Blower Motor Circuit
GMC Yukon HVAC Blower Motor Won Turn On
Dec 26, 2017 | Cars & Trucks
Where can I get blower motor circuit diagram?
you don't need a diagram . you system is so simple you only have 3 things in it and one never fails.
you have a resistor that if it fails it never works again , so that's out
the motor can be failing and then work again .
but fords most common is a blower switch ,it melts .
so remove the switch and then remove the plug(if you can it might be melted to the switch) and look inside there to see if it's deformed , the plug might be deformed as well as the wires burnt.
start there first.
Feb 01, 2016 | 1996 Ford Contour
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Fridgemaster MS91562FF American Fridge Freezer brand new but the fridge is 15C It needs to be lower? How do i do this?
then call that delivery person and demand it back . but there is a dial in the fridge part to adjust the temp just turn it to a higher number for cooler temp
Jan 10, 2016 | Fridgemaster Refrigerators
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
My home has a steam boiler that supplies heat for the 1st and 2nd Floors. There is a hot water system from the boiler with an InLine Armstrong circulator pump that supplies heat to the basement. The pump...
Yes, the manufacturer should have a parts kit for replacing the orings and seals..it's probably leaking right where the motor meets the impeller...there should be a seal inside there...the rebuild kit should have a blow-up diagram to assist you in changing parts
Jan 22, 2011 | Armstrong Tool Armstrong S25 BF InLine...
I have a pyromaster electric fireplace model HEF 33..my flame does not flicker ,it lights upand heats but no flame
I have the same model and problem there must be some part to get to replace it it seems to be a motor problem. would appreciate any ideas
Nov 09, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Dryers Logo
37 people viewed this question
Top Dryers Experts
