Question about LG 42PB4D 42 in. Plasma HDTV
I no longer receive the TV listings on my TV guide
LG 42PB4D. I have reconnected the cable, reset the antenna and cable channels and kept the set off overnight. Still no listings from the TV guide. Previously no problems with guide.
  • sccmd13 Mar 11, 2009
    I have a cable service through Qwest. The connections and reception are fine on the LG TV and another TV in the house.
    I have a simple cable connection without a box. This set up has worked fine with good info coming to the TV guide on the LG until recently.
    Top Expert:
  • LG Master
  • 77,169 Answers
I would call the cable service provider and ask to speak to customer support, we are not experts on every detail, when that is the case our job is to provide u with the resource to resolve the problem, so call quest customer support.
Posted on Mar 11, 2009
  • 275 Answers
Looks like you have signal problems. What kind of cable or dish company do you use? Because it looks like you might need to call them for help. I have DishNetwork and i had no signal issues, and i call them, they had to replace my box because it wasn't picking up any signal
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
Do you have basic cable or Digital cable. The listings only come when you have digital cable. If, its antenna then it wont work either. You will only get the listings if you have a cable box.
  • Prabs Pan Mar 11, 2009
    If you have the Digital cable then call the service provider for it. Then they will reset the cable box from the company.
My lg 65UF6450 has no TV Guide. It searches for active Channels but finds none. Setting them manually doesn't work either. My satellite TV service is on HDMI2 and works fine, just no TV GUIDE.
I have a TV like yours.
When you hook up an external antennae to pick up over the air channels, the TV will find the channels and display a list.
Your other TV services should come with their own channel guides.
Mar 10, 2016 | LG Televison & Video
How do I repair an LG 32LK330-Ub Auto channel tuning does not work.
If you have a cable box and your cable is attached with coax to the antenna or cable input you're probably receiving everything on Ch 3 or 4. If you don't have a cable box, then make sure the input / source is set to cable and not antenna.
Dec 03, 2014 | LG Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I got an American model of LG. i can not tune it by auto nor manual can you please help
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Nov 05, 2010 | LG 32LG30 32 in. LCD HDTV
I only get 12 channels. . .why?
Download the user's guide and go to page # 19 for more info on how to set up the TV to the proper input to receive all the channels.
Let me know if you need further assistance.
Jun 12, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Panasonic DVR, loss of TV Guide on-screen program listings
I had the TVGUIDE listing through my GE TV and it came across with a notice that they would no longer be putting out the listings. That was last year and the listing never showed up again. Your DVR may be recording digitally but if you can see it on a analog tv, it is using a analog turner and you will need a converter box to record once everything goes digital.
Most of the digital converter boxes come with a guide built in. I have the Magnavox and the Zenith and they work fine. You will need two converter boxes, one for the DVR and one for the tv, if you want to watch the tv and record a different show at the same time.
I would hook them up by splitting the antenna wire to the tv and the DVR. Then I would use the RCA plugs to connect the DVR to the TV and use the Input setting on the TV when I want to watch the DVR. You will have to set the converter box to the channel that is playing the program you want. The DVR will be set to channel 3 or 4 (whatever channel the converter box is set on to broadcast on) to record on, not the broadcast channel. Make sure the power saver on the converter box is set to off or the converter box will turn off after a couple hours and you will get no picture for the dvr to record on.
The digital signal is being sent over the air usually over UHF channels. It sent digitally but will be picked up by your antenna in the same way it picks up the analog signal thus there is no difference. There is no such thing as a digital antenna, thus a antenna from a Home Depot will work fine. I needed a outdoor antenna but the picture quality is the same as cable. Just make sure the antenna can pick up UHF and VHF signals.
Hope it helps!
Jun 02, 2009 | Panasonic DMR-EH50 DVD Recorder
RCA TV with Guide Plus that no longer receives guide at night
Please clarify what you are getting. Is the Guide Plus coming up with no programs listed? If so, it may be that you lost power and the set has to be turned off overnight to "reload" the program schedule. If that is not the problem, have you recently changed to digital through a digital receiver? You need to have your analog antenna connected to receive the program listings. You may have to install a splitter to have both the digital antenna and the analog antenna connected. I have an RCA with Guide Plus and ran into the same problem, but solved it by reconnecting my analog antenna and leaving the set off overnight to reload.
Feb 15, 2009 | Televison & Video
I have a LG plasma T.V., model 42PB4D. Black box/middle of screen
Try this:
In the menu go to CC and set the TV to CC1 as this is a text box appearing for captions. Hope this works!
Jan 11, 2009 | LG 42PB4D 42 in. Plasma HDTV
TV Guide on LG TV
I have the lg du-42py10x tv with a cable card slot. I have Time Warner cable in Cincinnati Ohio. I split their cable coming in and put one end on the cable input and one end on the antenna input on the tv. I now have TVGOS with my cable card. By putting one end of the cable on the antenna RF input, I received the CBS station in analog. That is what you need to get TVGOS to work.
Jan 06, 2009 | LG 32LX1D 32 in. LCD Television
LG 42PB4D 42 in. Plasma HDTV Logo
91 people viewed this question
Computer Repairing
Computer Repairing
