Question about Denon DHT500SD System
MY DHT 550SD WONT POWER UP, ALL FUSES ARE OK, CAN ANYONE HELP OR LET ME KNOW WHAT MIGHT BE THE PROBLEM, OR WHERE i CAN GET SPARES PARTS IF REQUIRED
Can anyone help me plz, i have a 37AW white knight dryer,my partner slammed the door too hard and the dryer hasn't worked since, has anyone got any ideas how to fix it, or tell me what to look for?
Probably broken the door switch which stops the drum when the door is opened. It may even just be the nylon strike pin that presses the switch.
White Knight 37AW Tumble Dryer Spares ' White Knight Spares
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw/catalogue.pl?path...ref...
White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 37 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Spring For Door Latch.
White Knight 37AW Tumble Dryer Spares - WhiteKnight-Spares, Parts ...
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw.../catalogue.pl?path... White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 36 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Door Window - Clear.
White Knight 37AW Tumble Dryer Parts ' Partmaster
https://www.partmaster.co.uk/tumble-dryer/37aw.../catalogue.pl?...whiteknight... White Knight Tumble Dryer parts - repair your White Knight Tumble Dryer with a ... White Knight 37AW Switch Strike ... White Knight 37AW Spring For Door Latch.
37aw white knight dryer door switch Google Search
Jun 06, 2018 | Dryers
No power
Can't find a 2005b model. Desktop or laptop? If laptop, look at the power supply, may have fuse in that.
Sep 11, 2014 | Computers & Internet
Flexible Shaft Adaptor # 2221-MA00009-00 Carbon Brush # 03AT-000046-00 Brush Spring # 02AH-000088-00 For a Mastercraft Maximum Spin Saw Kit Model # 54-8205-8 Cdn Tire...
By robert_lessa on May 09, 2011
Model # 54-8205-8
Cdn Tire doesn't support their own "house" brand with spare parts.
Does anyone know who was contracted by Cdn Tire to make this unit? That could give me an alternate source for spares. Any help would be much appreciated.
Thanks, Bob
------------------------------------------------------------------ Canadian Tire stopped supporting this product in 2008 and have no parts in inventory ( I am not convinced they ever had a stock of parts) The Spin Saw was manufactured in China by Choon Nang Electric. Your best bet is going to a small engine repair shop and ask if they have universal parts which could fit. Best of luck Claude
May 09, 2011 | Garden
My bike has no ignignition lights and wont start
Battery checks ok? Check fuses / breakers. Need to do some tests before anyone can really help you out. Pick up a cheap voltmeter from radio shack or autozone. Anybody who wants to troubleshoot an electrical problem should have this tool. Let me know about that battery voltage and those fuses and well move on from there.
Nov 23, 2010 | 1998 Triumph Tiger
Presonus firebox wont turn on
Get a flash light,look inside at the battery pack's connections(1) And then see if there's rust,a dull appaerance to each spot where the battery connects(2)Go to a radio shack and see if they have an equivalent fuse,and a manual for the fuses installation(s).Get Presonus online,and/or write them aletter about thier devives problems.
Feb 15, 2010 | PreSonus Firebox 6x10 External Sound...
Spares required.
Battery spec as per manual 1000m Ah x2 doesn't give the voltage but the charging addapter is 5volt 2.0amp.
George
Apr 24, 2009 | Mustek PVR-H140 Digital Media Player
Sharp 953 as if not plugged in. checked fuses internally and external all ok. Power goes to control panel although tested with volt tester pen.
The control panel circuit board may need repair, and it's possible the low voltage transformer has failed.
Some do it yourself tips here.
Info on ordering Sharp UK parts / spares is here.
For local servicers, see this page.
Aug 18, 2008 | Sharp Microwave Ovens
Sony DAV C450 No Power - Dead Unit
I am having this same problem. I have checked all fuses and all seem ok. Does anyone know what else might be keeping this from powering on? Any common problems that this one had to cause this? Also does anyone have a diagram of the schematics or the service manual?
Thanks in Advanced.
Jul 22, 2007 | Sony DAV-C450 System
Denon DHT500SD System Logo
44 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
