Question about Garden
Chainsaws types of fuels
Was there ever a chainsaw run by steam?
  • 398 Answers
I dont think so
Posted on Apr 03, 2009
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Carb leaks fuel while running
If its a bowel type you could have a sticky needle valve. If its a diofram type, you could have a hole in the diofram.
Dec 29, 2012 | Homelite C-52 Chainsaw, Antique...
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Where can I find a diagram for the fuel system ? I let a someone who new less than I did try to replace old fuel lines. it will crank and run untill carb. runs out of fuel.
An exploded parts list for a 4218 type 2 chainsaw follows (May not be your saw):
Poulan.com The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. They are also beneficial with disassembly/reassembly. Fuel components and part numbers are listed but may be on different illustrations:
http://www.ordertree.com/modelinfo/PWE/PP4218-Gas-Saw-Type-2/75.PP4218-Gas-Saw-Type-2.1.59.1.html
The dash number of your serial number is the type.
A very good general diagram of a 2-cycle fuel system can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using fixya.
Jan 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My chainsaw Model 142 - motor runs wide open with choke at 1/2 choke - will notrun otherwise
either fuel is restricted or air is leaking into motor inspect fuel lines fuel filter check for carb tightness or pull carb and clean. replace carb parts with kit
May 20, 2010 | Garden
Poulan 306 chainsaw
Drain the fuel from the tank and inspect the fuel line inside for flexibility and overall condition. If the filter doesn't flop to the lower side of the tank when the saw is turned, the filter won't be lying in fuel to be picked up and the saw quits. Use original type rubber line for replacement, not plastic.
May 10, 2010 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
