Sony kv-32fx65b i switch on but no picture no sound still blingk the red light what should i do pls help me master
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
How many times the standby light blinks at one time switch ON? These blinks are fault indications. From the number of blinks occur, you can get an idea about the faulty circuit section inside it. These are called 'Blinking Codes'. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter". Blinking codes to Sony TVs are described in detail.
Posted on Apr 20, 2013
Vrya
  • 62 Answers
SOURCE: SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Posted on Feb 19, 2008
jupits69
  • 4 Answers
SOURCE: KV HR36 Sony Wega, 10 blink and turn off...
try to replace the horizontal out transistor
Posted on Jul 18, 2008
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
jingjao
  • 252 Answers
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Posted on Oct 14, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
When I turn the tv on, no picture and only the stand by timer
Sound to me like your video amp failed on the C board. This board connects directly to the back of the CRT tube. It actually has the letter C on it. The video amp is IC702, PN: TDA6108JF. You can locate a vendor for the part by googling the provided PN. This amp is fairly cheap and not too difficult to replace if you can use a soldering iron. However, you must apply heatsink compound or it will over heat and fail more quickly. You should be able to get a tube from the same vendor as the amp. I hope this was helpful, best wishes.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Red standby light flashing no picture or sound
the power supply is faulty, check the following
power trasistor
rectifier diodes
zener diodes
fusable resistors ( less than 20ohms)
and your set will work again
Apr 07, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
32" Sony Trinton Wega
Count the flashes and verify that the model is KV-32FS100. The flash count will indicate the circuit in which the problem was detected.
Thanks,
Dan
Oct 28, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
