Dual 1257 Automatic Belt Drive Turntable manual
Need to change the drive belt but have no instructions
  • 14 Answers
SOURCE: i have just a basic belt drive turntable and the
Hi There.
If the belt falls of the platter, it might be an indication that the belt has stretched and is now too large. Or maybe it just fell off for any other reason.
Remove the rubber mat, and pull upwards on the platter to remove it. Sometimes there is a small "C" clip on the center spindle that has to be removed first. (use a small flat screwdriver to remove)
Turn platter over, and put rubber belt around diameter ring on underside of platter. It should be snug, and not fall off when you turn platter over.
Put platter back onto turntable, and spin by hand until you see the motor shaft through one of the holes in platter.
With a pair of tweezers - or crochet hook, put belt over shaft.
You're done.
Put back rubber mat and give it a try.
Good luck,
Fred
PS: If there was a "C" clip, you can re-install it - or throw it away.
Posted on Sep 25, 2009
informatica
  • 1114 Answers
SOURCE: Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 27, 2007
djproaudio
  • 515 Answers
SOURCE: Optimus 1000 belt drive automatic turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
djproaudio
  • 515 Answers
SOURCE: drive belt on Sony turntable
- OPTiC
www.1200s.com
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Prolectrix usb turntable
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
Feb 27, 2014 | Audio Players & Recorders
Need Instructions to replace belt on panasonic SL-5N Turntable
To replace a turntable drive belt.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Apr 11, 2013 | Audio Players & Recorders
I am assembling a sony turntable and don't understand step 3. Using the ribbon, loop the drive belt around the motor pulley. PS-LX300USB model Thanks
Manuals and belt instructions here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=PSLX300USB&LOC=3
You would handle the belt by the ribbon instead of bare fingers so your finger oils wouldn't contaminate the belt. You stretch the loop of the belt over the drive pulley between the flanges to hook it.
Nov 07, 2010 | Sony PS-LX300USB Turntable
Lenco l3806 turnable does not spin
Your turntable is Semi automatic and Belt drive..The belt is made of rubber which becomes rubbish by years and it melts..
You need to replace it. You can find it on" ebay"..the best source for such parts.
Please visit the web site below to find about necessary instruction manual for this job.
good luck..
http://www.lenco.eu/index.php?option=com_content&view=article&id=1:l-3806&catid=1:platenspelers&Itemid=3&lang=en
Downloads pdf.gif leaflet pdf.gif manual image.gif image
Oct 06, 2010 | Audio Players & Recorders
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Serpentine belt replacement
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Jul 24, 2008 | 1999 Ford Escort
Ion ittusb turntable drive belt
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Jan 28, 2008 | ION Audio iTTUSB Turntable
310 people viewed this question
 Grubhead
Grubhead
