Question about Cobra HH 38 WX 40-Channels Handheld CB Radio
The voltage for charging and plug-in power, cobra hh35?
I need the voltage for charging and plug-in power, cobra hh35?
  • truktolstad Mar 12, 2009
    THANKS, I'LL CHECK THE SHACK.
  • 40 Answers
The voltage for the charging is 12 volts dc the charger is a 110 volt dc 12 volt to the radio if you lost your charger you can get a aftermarket at any radio shack store just be sure you take the walkie with you when you go so they can match up the rdio plug end.
Posted on Mar 12, 2009
  • james morgan Mar 13, 2009
    i believe it is a hh38
If i ask a question is there a charge for the answer?
no charge!go to ebay all cobra radios have the same plug and cord you can get one at about $6 bucks or cheaper
Feb 14, 2015 | Cobra Radio Communications
My cobra hh35 two-way radios one will not trasnmit more than 29 yards?
Do you have it set on low power? There is a power setting in the menu that will fix that problem.
Nov 23, 2014 | Cobra MR HH330 FLT VHF Waterproof Two-Way...
MY COBRA MICRO TALK BATTERIES WILL NOT CHARGE HOW DO I KNOW IF THEY ARE CHARGED?
if you have a volt ohm meter see if theres voltage at the power adapter plug or the battery itself
Aug 09, 2014 | Cobra MicroTalk CXT145 Walkie Talkie...
My cobra hh35 handheld will turn on and key up but will not receive on any channel
do you have a home base radio? Connect the coax to the HH35 and see if it makes any difference.
Jun 30, 2014 | Radio Communications
I am look for a Antenna for a cobra model no is HH35
Any "Rubber ducky" antenna for a CB radio will work. It has to be one that is designed and tuned for the 27 mhz CB band.
Here is one.
You can also just google the phrase "cb bnc rubber ducky" and it will bring up lots of options.
Oct 18, 2010 | Cobra HH 38 WX 40-Channels Handheld CB...
Any online manual for Cobra model HH35 CB
HI,
thr is no online manual availabel
http://www.cobra.com/pages/product-manuals
but you can email the support of cobra to provide it or mail you.
it will take time to update in thier website officially,wait for a week.
ask the manual here,they will provide you
http://www.cobra.com/support/ask
Sep 23, 2009 | Cobra Radio Communications
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
Mar 25, 2009 | Cobra Radio Communications
Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Jun 28, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Cobra Model HH35 radio dummy batteries
Normal AA batteries are 1.5 Volts each. The battery compartment on the HH35 holds 10 Batteries. If regular batteries are used they must be configured to a 12 Volt output. Thus the Dummy (Blank) is used to Make 8 X 1.5V=12 Volts.
If you use NiMH or Nicd which are rated at 1.2 Volts 10 X 1.2 =12 Volts.
Nov 21, 2007 | Radio Communications
COBRA 40 CHANNEL HH35 HANDHELD
The plug in for theese radio's are junk, I would look inside by the plug in on circut board probely needs resoldering and try to clean the plug in part with electrical cleaner and a very small screw driver to scrap the connections and take out the batteries first!!! also check your batteries make sure each one is good = 1.4 volts or more
Oct 27, 2007 | Radio Communications
Cobra HH 38 WX 40-Channels Handheld CB Radio Logo
650 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
