Question about Kenwood VRS-7100 Receiver
How can i get a volume control switch for a kenwood kr-v9030
  • 11 Answers
SOURCE: have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Posted on Jan 06, 2008
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 4234 Answers
SOURCE: sound problem
Try cleaning the volume control with an electronics switch cleaner spray. If that does not resolve the problem and it seems to happen at low volumes more than load volumes, then the output relay needs to be replaced. Keep us posted. Dan
Posted on Jun 12, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood kr v 6080 keeps shutting off when you turn
Receiver say's "Protect" or turns on then off posted on Dec 13, 2009
MessageRate.ThreadID = 3632423; MessageRate.ProductID = 0; c81ea4d.jpg smarthome2
Rank: Guru
Rating: 88%, 432 votes
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers2_bing.gif one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Feb 28, 2010
SOURCE: Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Posted on Jan 08, 2011
Kenwood kr 5050 volume stuck on high cant change
These days the circuit of the volume control is controlled by an IC in modern amps. These can go faulty preventing adjustment of the sound by the volume control. The only cure is to find the IC and replace it. You can start in the area where the volume control is located. If it's not mounted direct on the PC board, follow the connections to the board. Hopefully the board might have writing on it to indicate the area where the faulty IC is.
Aug 04, 2015 | Kenwood Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
I have a Kenwood KR-V9030 and the right channel is crackling and will not provide increased output when the volume is turned up. 1) Swaped speakers from left to right and the problem is in left speakers...
There is a chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure.
One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you're losing it in the preamplifying or source selection stages.
If it CAN be played externally, the receiver is losing it on its way to or at the amplification stage. Further isolation would require hands-on technical expertise.
Apr 16, 2011 | Audio Players & Recorders
Kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Jun 07, 2010 | Audio Players & Recorders
Mar 08, 2010 | Kenwood Audio Players & Recorders
Sound problem
Jun 12, 2009 | Kenwood Audio Players & Recorders
Volume control for kenwood krv5580
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
Jan 08, 2009 | Kenwood KR-V5580
Have a kenwood KR-V990D and can't seem to bring the volume up
Jan 06, 2008 | Kenwood KR-V990D Receiver
Kenwood VRS-7100 Receiver Logo
46 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
