Question about SMC Netgear 5Port Gigabit Ethernet Switch 10/100/1000 - GS605 [ Netgear GS605NA ] (114630)
One computer connected the other limited or no connectivity
I was running 2 computers off a router .....I requested 2 ip address's from my ips provider ...I bought the netgear5 switch and 1 computer is hooked up and online fine the other says limited or no connectivity
  • 71 Answers
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Posted on Mar 15, 2009
How to find a IP address for my emachines laptop
go to start -- run and type in CMD
hit enter to open a black command prompt window
type in "ipconfig" without the quotes and hit enter. This will give you your IP address.
If you need the IP address from your provider that you are using out on the public internet, just go to and it will tell you what your external public IP address is.
Mar 06, 2013 | E-Machines eMachines Desktop PC
It does not make much sense. But it seems the WAP610N has a limit on concurrent connections. We just started to use this device in a small office network. There are about 15 laptops on wireless...
Two possibilities:
1. the router is configured to hand-out IP-addresses in a limited range, e.g., to, namely 11 different IP-addresses. When the 12th computer asks for an IP-address, there is none available. Remedy: configure the router to use a larger range of IP-addresses.
2. when an IP-address is handed-out, attached is a 'TTL' ("time to live") value, indicating how long the IP-address remains valid, e.g., 10 minutes or 100 minutes or 1 day or 1 week. If the TTL is too large, then each computer "hogs" the IP-address (even after being shut-off in mid-afternoon).
Remedy: configure the router to use a shorter TTL. Don't worry: when a TTL value drops to 50% of its original value, on a specific computer, the computer will "renew" the lease.
Mar 18, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
Switch D-Link DES-1024R + My problem is not gateways automatic
No It's not virus . It is issue of ip address in your computer. You can set ip address with 2 method static and DHCP. For DHCP you need to enable it in router. Connect your router to computer with ethernet cable then you can access it with following default link. or or or If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP and enable so you can get ip from router.Enable "ip get automatic in network adapter tcp ip property. If you want to ser static ip in tcp ip then gateway ip set to router ip if your router ip is then your computer ip is subnetmask and gateway as Then you can access internet Let me know if you need further assistance. Thanks for using FixYa.
Jul 19, 2010 | D-Link DES 1024R Plus (DES-1024R+/5)...
My laptop is saying
This error comes when there is same ip address in 2 computers.
So make sure in networks there are not same ip address.
You can also solve this issue with DHCP .
Enable DHCP in router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
Enable DHCP if you want to get ip from router.
Then set "ip get automatic " in network adapter property.
Mar 11, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
Even though I have all of the signal bars, my laptop cannot connect to my wireless, claiming there is limited or no connectivity, and that the network did not assign a network address to my computer.
Normally a router is set up to issue IP addresses and computers are set up to request IP addresses (via DHCP). Occasionally one half of the pair decides not to play ball - more often than not it's the router - and so the computer ends up with a 'self-assigned IP address' - generally starting with a 169 instead of the usual 192 or 10. When this happens the computer will never talk to the router so you never get your connection.
As a rule, removing the power from the router for about 5 minutes and then powering back up and waiting for all the lights fixes it. However, it doesn't always work. When that happens I generally reboot the computer and if that doesn't sort it I go into the network control panel and set the computer with a manual IP address. Say the router's IP address is, it set the manual one on the computer to (and make sure that the subnet - that's the - setting is the same as the router's).
See how you get on and post back.
Feb 14, 2010 | D-Link 802.11g Wireless Router WBR-1310...
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like If you have an IP address like you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Comuter gets a 168 private ip
enable DHCP on the router and you'll get the right ip adress
Aug 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
Voyager A210 Laptop shows when connected to wifi "Limited or no connectivity"although others are connected on same router at the time. I have removed wifi program and reinstalled No difference
This is just a try. Find out the Default Gateway on the other computers. If they are using a static IP then you need to get on. At someone else's computer click Start and Run and enter Cmd and click OK.
Now type in ipconfig /all. Look for IP Address, Subnet Mask, Default Gateway and DNS Servers. Write it all down. Then find an available IP address by using the Ping command.
In the same Window, type in ping and the IP Address of the computer you are at. That's just to show you what it looks like when you find an IP already taken. You'll see "reply from..." with the address you just pinged. Now ping again but change the last octal in the IP (the last number) in the IP address to something under 256. And ping again. Do this until you get a message "request timed out". You've just found an available IP.
Mar 27, 2008 | Computers & Internet
Limited or no network connection
looks like the dhcp is your problem.
the error is telling you that its an internal network providing limited access.
go to run cmd then in the dos prompt type in ipconfig /all
see your network card's ip address. if its 169.x.x.x then thats the problem..u are not getting the ip address from your computer.
go to your network connections right click the network card then go properties in the tcp/ip area assign yourself a manual ip address of 192.168.1.xx
the xx is a number that u like 2 digits only but it can't be 1
your default gateway is your router so give it
this should solve ur problem
good luck
Jan 19, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
277 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
