Question about NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor
Need to take the back off the monitor to fix a part
Nec 1700v lcd monitor turns on the turns off need to get the back off to see inside have removed the screws but unable to get the back to lift off am I missing something
    President:
  • 814 Answers
Yes you will need a plastic putty knife or plastic pry bar . You need to find a open space put in the plastic and slide it up and down and around the edge to unlock the plastic locking mechanism that keeps the bottom and top of the monitor casing together. You must do this very carefully so as not to break the locks. If you do break some of the locks. You will have trouble keeping the case closed around the edges. To do this you need a large table space and you need to pad the surface. Place the face of the monitor down and work at separating the back from the front.It take patients. After it is done you will be able to see the power board and main board. They may be covered with a metal heat shield, that will have to be removed.Make sure you take notice of where the screws came from as they may be the only right screw for the hole. You should use anti static wrist bands and gloves to make sure you don't discharge static electricity in to the components on the boards, doing more damage. I hope this information helps you with your problem.
Posted on May 24, 2009
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
Recieved "No Signal Imput" after relocating computer and monitor
You need to check VGA cable connections at both ends, check video card to make sure it is seated properly in to the PC slot, etc. Try this monitor with other PC as well.
http://s807.photobucket.com/home/budm/allalbums
Apr 22, 2010 | NEC 17" 1700V TFT LCD Monitor 1280X1024...
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC multiSync 1700V as external monitor for Notebook Toshiba U205, Operating System Window Vista Home Premium. It displays only part (80%) of the picture compared with notebook's monitor.
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
Nov 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
I hooked my new computer up to my NEC Multisync 1700V moniter. When I power the moniter up the GREEN light comes on until I get a "no Signal Message" and then the amber lihgt comes on.
hi, hook up your old one and change the refresh rate to 60 or 70 hertz, go 2 display properties, then the settings tab, then advanced,then monitor. and set it as i said. turn off computer after you change settings. hook up the nec, you then should be good 2 go. good luck! and please rate this solution. if you need further help, reply.
Apr 13, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Bought a new computer. Getting no signal from my multisync 1700V
check the device manager and see what it says for the monitor...I know you can press CNTRL+ F5 for monitor selection , try this if everything is good in device mngr
Remove the back on NEC LCD 2010X
Remove the 2 screws from the bottom of the screen at the back of the monitor. Half way between where you removed those screws use a flat tip screwdriver or similar to push the back plastic shell in & up to release the clip holding the 2 parts together. Similar clips also hold the top sections together. Good luck
Mar 19, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
My Dad bought a NEC 1700v Monitor about 5 years ago. Its a good monitor and the picture/color is still good but it blacks out after it shows desktop for about 10 seconds. To get it to come back on, can...
This is a CRT monitor right? Do not open the case! There is high voltage stored in a capacitor somewhere in there and you could get zapped. You can buy good used monitors at Goodwill or a computer re-cycler for $20.00. If yours lasted five years you got your moneys worth. Did this monitor work correctly on other computers? If it did maybe you have a problem with your graphics card or something in the computer itself. Try a different monitor on your computer. If everything is OK with a different monitor then you know that your computer is good and that is not the problem.
Nov 30, 2008 | NEC Computers & Internet
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Logo
339 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
