Question about Gateway GT5056 PC Desktop
My icons and tool bars are so big nothing I bring up fits on the screen.....I can make the internet smaller with the mouse wheel, but it shows in a very small space because of the very large tool bars. Can't gert to the 'approved' part of the resolution because it is so large it doesn't fit on the monitor.
  • Harry333 Mar 12, 2009
    Thank you....it worked, but only brought up the choices on the next line....'approved' is on the line below that...
    Novelist:
  • 166 Answers
Here are some tips to help you move around when you can't see other parts of the screen
Alt + Tab (hold down Alt and press tab) will move you between open windows
Tab will move you from button to button and to the file menu at the top
Shift + tab will move you back, for example if you hit the tab key one too many times
Alt + F4 will close the open window, if no window is selected it will bring up the shutdown computer screen
F5 will refresh a page on the Internet
F11 will switch between Full Screen mode and not full screen mode
So try getting to the "approved" window and then using tab to select it.
Posted on Mar 12, 2009
How do I change the desktop text, icons and bars back to 100% from 500% in Windows 8.1?
Hi Cindy
You have set a customer DPI scale for your display.
Right Click on desktop
Choose "Screen Resolution"
Click on link that says "Make Text and other items larger or smaller"
Click on link that says "Set custom text size (DPI)"
Adjust the scale back to 100%
Apply the changes and all should be well.
Regards
Andrew
Make the text on your screen larger or smaller Microsoft Windows Help
May 18, 2014 | Acer Aspire Computers & Internet
Text, Icons and Bars set at 500% cannot change
Hook up a mouse with a scroll wheel if you have one, hold down the ctrl key on your keyboard then scroll down on the mouse wheel. See if that works. If it's your desktop that is big as well, right click the desktop, click where it says screen resolution and change it to make it smaller. If that doesn't work let me know and we will try something else for you.
May 05, 2014 | Acer Aspire Computers & Internet
How do i get full screen to show command bar again
I assume you mean Internet Explorer. A trojan resized your screen so large that you can't resize it? Try control panel/display choose a smaller resolution and then go back to the regular resolution. Your browser should resize automatically.
Nov 27, 2013 | Computers & Internet
Bold letters
Did you icons get big too? Pressing Ctrl + Mouse Wheel Scroll with make your icons bigger (also Right-Click > View > Large, Medium, Small). Did your resolution change? In Windows 7 and 8, you can check your resolution by right-clicking on the Desktop and select "Personalize". From there, select "Display" located to the lower left of the window. This should show you three options: Smaller, Medium, Larger. Choose the one you like the best. From here you can change your computers Resolution by clicking "Adjust Resolution" and select the one that shows you the most screen that you are able to still read. Most websites are designed to a minimum of 1024 by 768, so I would select at least that.
May 16, 2013 | Dell Computers & Internet
How can i make my letters bigger
you need to change your font and size settings. If it it isn't on the tool bar, right click mouse in tool bar (top of screen) area and choose tool bar properties. You may need to move mouse over different areas , don't give up, right click is your friend.
Sep 21, 2012 | HP Computers & Internet
My screen of computer is so big the contents are enlarged my kid has pressed some buttons pls help
Hi nayyarshelly,
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
  • First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
  • On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
  • If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
  • But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
  • Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
  • The resolution on your screen depends on how big the LCD screen is
  • On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
My screen is showing Big Icons How do I shorten my screen.
Hi:
Right mouse click anywhere on the screen, then select properties, or personalize, depending on your version of windows. Next find display properties, and adjust your screen resolution higher, and your icon's will be smaller!
Oct 05, 2010 | Dell Inspiron 530 -Intel® Pentium®...
How to use internet on psp
Fully charge your PSP. Using WiFi requires a lot of battery power.
Verify that you have access to a router or HotSpot. If your router is password protected, then be sure you know what the password is. Be aware that some public WiFi access point are incompatible with the PSP.
Update your PSP's firmware to the most current version. Newer versions of the firmware have better Internet features than older versions.
Turn on the WiFi switch on your PSP. On older PSP models this switch is located on the left side of the device. On newer models, it is located on the top of the device.
Select the Internet icon from the PSP's main menu.
TO START BROWSING
Look at the screen once the browser loads. By default it will load the Sony webpage. You can set your own homepage later.
Use the analog stick to control the mouse cursor. The "X" button is equivalent to clicking the mouse.
Use the circle button to reject a choice or to disconnect from the Internet.
Press the triangle button to bring up the address bar at the top of the screen and the options bar at the bottom of the screen. Selecting the address bar, or any place on a webpage that requires text entry will automatically bring up the virtual keyboard screen from which text may be entered.
Choose the icons along the options bar at the bottom of the screen to change settings, set a new homepage or access other browser features such as browsing history, bookmarks or help. Tool tips will help you identify the features you are looking for.
Press ENTER to look up in Wiktionary or CTRL+ENTER to look up in Wikipedia
Sep 30, 2010 | Sony PSP-3000 Silver Console
How do I fix the size of my icons and make the internet fit to size
How to resize Vista desktop icons
One of the complaints I hear about the Vista GUI is that "the icons are too big." Well, fixing that is a simple matter. Here's how:
Right click an empty space on the desktop.
Select View.
Click Classic Icons.
Another way is to use the scroll wheel on your mouse or trackball. With the cursor on the desktop, press and hold the CTRL key and scroll the wheel to make icons larger or smaller.
I hope someone having that problem will read this thread.
Cheers!
Jun 24, 2010 | Microsoft Windows Vista Home Basic Edition...
Gateway GT5056 PC Desktop Logo
267 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
