Question about Lowrance Elite-5 DSI Color Combo Fishfinder/Chartplotter with GPS & Transom Mount Transducer 000-10236-001
How to install lowrance elite 7 hdi - Lowrance Elite-5 DSI Color Combo Fishfinder/Chartplotter with GPS & Transom Mount Transducer 000-10236-001
HI my name is ED I need to get another Operation Manual Elite-7 combo HDI mine got all wet and stock together.
Do you mean the Lowrance Elite-7 HDI? Most Lowrance manuals are available here: http://www.lowrance.com/en-US/Support/Documents/ . Click on the Elite series and then scroll down the list in the Select Product window. Then look at the lower right side of the page. The Operation manual and installation guide are both available. The direct link to the operation manual is currently http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf .
I hope this helps.
Feb 23, 2017 | Boating
How do I set position on my lowrance hdi 7
The GPS will automatically triangulate your position and display it on the map screen.
If you have your cursor turned on the the map screen will remain centered on the cursor.
while on the map screen push the Menu key and then the Enter key. If you notice the pop up window when you push menu you will see the first field highlighted will be to return to current position or something similar. By pushing enter you are selecting this option and the unit will display your current position on the map screen.
Oct 17, 2014 | Lowrance Elite-7 HDI...
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
How to change language to enlish
Hi Kane,
I have this manual for you on how to set up setting up Language on page 42 to 43. Hope it helps.
Apr 25, 2014 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
My Lowrance Elite-7 HDI Chartplotter will power up but does not go beyond the start-up screen. Acts like it is frozen.
Sorry it sounds like your your unit has a fairly major problem with the software. You better get in touch with Lowrance as this may still be under warranty.
Aug 06, 2013 | GPS
How to wire a lowrance elite 7 hdi
Hi Everyone, Has anyone install EP-60R Fuel Sensor unit to Elite 7 HDI ? I have hustle making it work. Appreciate if anyone successfully solve similar problem. Dan
Jan 19, 2013 | Lowrance Boating
Lowrance Elite-5 DSI Color Combo Fishfinder/Chartplotter with GPS & Transom Mount Transducer 000-10236-001 Logo
631 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
