Question about Refrigerators
Fridge model WB5534XP - Refrigerators
I have a IARP fridge freezer model stok 140 bt and I understand it can be set to either fridge or freezer. How do I change it from fridge to freezer?
can you tell about exact model number of your IARP Fridge its printed on back side of fridge or on a metal plate on it.
Aug 26, 2015 | Refrigerators
Cubic feet of my fridge and freezer model #ED5CHQXVQ00
The model number usually depicts what size fridge it is. ED 5 ?? That would suggest 5 cubic feet. ?? In Australia, fridges are measured in litre size. IE/ a fridge with say a model of HE550 would suggest 550 litres ( a reasonably big fridge)
Apr 09, 2015 | Refrigerators
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
Whirlpool fridge WB5534XP-Aa problems fridge warm up and cannot hear the compressor starting
That is still enough time for oil to go into the evaporator and cause problems for the compressor starting. Keep it upright and don't leave the power plugged in while you are away. Plug it in and try for about five minutes at a time. If it does not start then come back later and try again. Eventually it will start so when it does I believe you will be good to go! Let me know if you continue to have problems or if this works for you, Thanks, John Tripp Appliance 911 if need
Contact Me Here
Feb 24, 2014 | Refrigerators
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
My LG French door fridge, the food freezes when it is placed near the back of the fridge.
There are three possible causes for this:-
1. You have food in contact with the cooling plate at the rear of the fridge, or very nearly so: it should always be at least an inch away and most fridges have shelves designed to assist this.
2. You have the fridge thermostat set too low.
3. You have overloaded your fridge and so the very cold air at the back of the fridge cannot circulate, creating a local zone which is far too cold.
Your fridge instructions will usually have warnings advising how to avoid these problems.
Some fridge models rely upon circulation fans to ensure an even temperature distribution and these may fail to produce the same effect, but such models often (not always) have an audible or visual warning if the fan(s) have failed.
Unfortunately you have not specified your precise LG model number so it's impossible to be any more specific.
Aug 15, 2010 | Kitchen Ranges
Fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Mar 27, 2009 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
